As discussed before I have seen many S1’s on google searches etc that have pretty poorly fitting front stone chip protectors, where they don’t cover the ‘intake’ area properly and you can see the flat surface around them.
I used some thin card to cut and shape the template I needed. It was actually the card I used when spraying so one side was matt black like the stone chip material which was handy. It took lots of trial and error as it isn’t really a space that is easy to measure and trace but eventually I got the first template where I wanted it so that no flat surface would be showing (I actually finessed the edges a little after this picture).
I was hoping to get away with just doing the one template but as with most things on this car there isn’t much symmetry. The passenger side template was a fair bit longer and less ‘tall’ than the driver side. Every clam will be slightly different, so anyone who wants to do similar I suggest making your own vinyls to custom fit your clam and save yourself £60.
Or you can do something like this and cut just the end out and route a cooling pipe, which if it is black and you have a vinyl on the remaining bit of intake you probably wouldn’t see either. I was tempted with this and may do later on as my car is quite track focused.
The bottom instrument shroud piece has had one of the front fixing holes broken for ages, meaning that the screw isn’t able to hold it nice and tight, leaving a gap between the two pieces on the right hand side.
So I took one of the M4 spire nuts I was planning to use for the numberplate light and cut it in half and glued the holed piece to the inside of the shroud.
Cars are tough to drive without seats as each time the car moves you do too, so a few stalls but made it onto the trailer ok. Strapped down and with a car cover on it to help keep the wind from ripping the clams off.
I was only told last night that the bodyshop was able to take the car in, so I quickly tested the rear clam/roof fixings and cup washers. Thankfully all the holes and jacknuts lined up as they should and the cup washers look good. They’ll be fitted with small rubber washers to protect the paint on final assembly.
I’ll try and get some pictures of the car in the bodyshop at the different stages, but I’m not close to the shop so might be a bit tricky with the lockdown situation etc.
I think I’ll be able to see after primer (perhaps just before) but this could be the last chance to guess the colour, some probably know already
My Dad’s mate runs a bodyshop in Hertfordshire, so hoping for a bit of mates rates
Hopefully don’t have to wait long to show you the colour, he has a 6 week deadline for it but he might want to crack it out and get it done. All the loose bits are ready to go with priming, it is only the clams and roof that need DA-ing.
Got the new smaller roof clamp bungs delivered so gave them a test fit. They are probably slightly too small as rather than having a lip outside the hole, they sit fully flush.
This probably shows what I mean a bit better, it probably looks better than if they were a bit bigger to be honest. They’re not the highest quality but who is going to look at them anyway.
Have to be a little careful getting them out as there isn’t a lip to lift, so I have to push and twist them. I did one wrong and accidentally just pushed it flush in the hole and had to use a pencil to push it back through, obviously something I wouldn’t be able to do with the clamp on the car.
A big thank you to my mate’s dad who did a great job powder coating my loose bits for me. He said he can do matte as well so may get him to spray my wheel nuts if they end up being too tatty and scratched up from the spray can paint.
