In tonights’ episode…
I first off got my donor backbox fitted, looks like an OEM 111R one - shockingly heavy and touched just about every piece of bodywork and heatshielding when in stalled… how standard cars don’t rattle themselves to death I don’t know…
They look very sporty though…
Anyway, rattle still persists - so I can cross the backbox off the hit list for now. Obviously the fluff I found in the tailpipe still needs monitoring though, could be early signs of problems - but it’s not THIS problem.
I decided to push on and get the manifold off, I’d checked its nut/bolt torque a few days ago but I could at least have a good inspection for any small cracks, however unlikely with it being a month or two old.
What I found gave me a glimmer of hope, even if my ever supportive peers don’t think it’s likely
This is the gasket supplied by 2bular, it’s different to the toyota design in that it’s a single element perforated crush gasket. Lotus/Toyota use a double layer metal one which luckily I had new in box (bought before I realised 2bular came with one supplied).
It looks like it may have been blowing a bit, the gasket itself is undamaged but the soot marks extend to the edge of the gasket which suggests to me that gas is escaping somewhere. Whether it’s rattling its way out at 7500rpm is probably unlikely though, but regardless something that should be fixed.
The 2bular supplied gasket also had a strange attribute in that the bore holes are oversized for the exhaust ports on the engine and the manifold bores.
I did notice this when first fitting the manifold but thought it best to use the 2bular supplied one because… surely it was right for the application. I’m now not too sure.
You can see on the engine side of the gasket that the gasses have been leaking into the little recess machined into the block between the 3rd and 4th chambers.
There’s also evidence on the mating surface of the gasses escaping.
One other thing to note, the manifold is held on with 3 bolts and 2 studs/nuts. One of the studs was only hand tight in the engine, though it’s nut was on tight. Both studs got removed, cleaned up, loctited and refitted.
Again, all long shots - but a few more niggles out of the way. If nothing else I’m chewing through small problems that may have surfaced in the future anyway!
