Im not sure why, probably how David has the forum set-up but the images aren’t very big when posted on the thread. They are however quite high res images so if you use the zoom function on your computer the detail gets better…
[quote=TarmacTerrorist]Yes your right it is a set of ear protectors…
Im not sure why, probably how David has the forum set-up but the images aren’t very big when posted on the thread. They are however quite high res images so if you use the zoom function on your computer the detail gets better… [/quote]
Yeah Gav will tell us all anything. I reckon he will use them to keep his ankles warm…
Don’t be too keen on adding brake cooling ducts. Have only come across 1 Elise/Exige that did need it since '96, and only at one track, and it wasn’t an S2, and it had way more power than you are going to have.
Put some of the funky AP brake paint on first to see what temps you are seeing. It wouldn’t surprise me if you will never need them.
Not a lot to update this week so far guys, I must admit I’ve had a few days off from it while I’m waiting for the brackets to be made for mounting the sides of the front clam to.
Soon as they are back with me which should be tomorrow and ive got them in postion the front clam will be all but done and I can send it off to the paint shop for prep and prime.
I’ve been promised next week for the pedal box so providing it arrives I can get the rest of the front finished and start in the cabin.
Only thing I’ve managed to do is play around with some ideas for the i/c ducting from the roof scoop. Of course I had grand ideas of fabricating some fancy ducting but after racking my brain how to keep it simple and be flexible, I found out an old piece of 10" spiral ducting which was lurking at work which I think will do the job nicely. It was round when I started but with a bit of squishing it will go pretty much in to the shape I require. I just need to buy a new piece which is a bit longer and not all manky.
Paul from Heaton Park Coach Works has been in this afternoon to look at the rear clam, roof scoop design and other bits he is going to need to do before he can paint. I think I gave him a mild heart attack… Good on him though he said he was up for a challenge, and I know he will do an excellent job.
