Hmm, I would suggest shopping trolley wheels, I belive they weigh very little, run flat tyres as well come as standard.
I would love another set of wheels, I had a set of speedlines on order for months when they were supposed to have been 3 or 4 weeks.
I couldnt be bothered to buy them in the end as they couldnt be bothered to contact me and tell me they were going to be late.
Im now probably going to buy some compomotive MO’s to put some road tyres on and take off the standard alloys with my 48’s on for the winter and to save for some trackdays next year.
I belive the compomotive’s weigh more than standard but to be honest i dont care im too busy driving it to bother setting it on some scales.
Just got the new EVO Mag with their supposed write up of the tuner GP, which is rubbish, they will be getting a letter from me.
My car weighed the most out of all the lotuses there yet still managed very well.
Anyway off to get me some trolley wheels, hopefully ones that dont pull to the left all the time.
I get the impression we’ll never get anywhere near the truth…
Uldis - to be fair we are not that far apart with regard to the weights for the rears with AO39s. Certainly within a combined manufacturing tolerance together with inaccuracies in our scales.
There just appears to be a discrepancy in the weight of the front Rimstocks…i have put everything away now so dont really want to remeasure but if Ian confirms his figs as correct then I’ll re-do mine…not that I’m saying he is wrong!
SteveJ, I keep meaning (and forgetting) to tell you. Your wheels are not the original Exige ones. They’re actually Lotus Motorsport ones. I believe the fronts are the same, but the rears have a slightly different offset. In theory, you’re supposed to use thicker brake discs or spacers with them, but I never had any problems. Shouldn’t be an issue but I thought you should know. I had to sign a disclaimer saying they were intended for track use only etc.
Are you sure? Can’t quite see why a different offset would have any effect upon the brake disk thickness - isn’t that a factor of the caliper, ie distance between the pistons excluding pad thickness?
Sorry, I was talking about the thickness of the bell, not the actual disc area. The motorsport wheels are designed to be used with the motorsport discs.
I can understand the Motorsport wheels having a larger offset, ie, a wider track, if the Motorsport calipers would foul the standard wheels. However, I thought that the Motorsport wheels had less of an offset, ie, a slightly narrower track. I had assumed that this was an additional effort to try and reduce the stresses on the wheel bearings which were failing too regularly early on in the Motorsport programme?
I have a set of Motorsport wheels so could check the offsets if anyone wants the actual figures…
I certainly noticed more touching of the wheel liners after using the Motorsport wheels…but they were fitted with slicks so your explanation might be right.
