You know for a fact…
Steve, there’s a common element on your posts, Simon is not inherently wrong on anything he says, nor are you.
Just chill out.
From the owner of said engine himself:
This was my Exige,and for those interested these are the facts.I fitted the Simon Erland built K into my car and after some fuel pump problems it was running and was sweet(although still on axle stands and minus rear clam)just as I was about to fit the clam I couldnt help but want to hear the engine again.....it was running pretty badly,explosions and flames out of the exhaust.After talking with Simon we agreed that the best course of action was to take the car to Emerald since Dave could probably sort the problem and at the same time put a running in map into the ECU. With the car on the rollers,it was started...bad missfire,after a brief discussion and a bit of chin rubbing Dave swapped the plugs and hey presto....it was running. After 10/15 mins mapping dave shut the engine down being unhappy with the noise he was hearing......engine didn
t want to turn off the key or rocking the rear wheels! also Dave noticed grass' inside the timing pulley cover,which turned out to be a small amount of shredded belt. Basically something had got behind the oil pump pulley and minced up.Thankfully the only damage was the pully.as regards what got in behind it,well that
s a mystery…no bolts were missing,Dave definately hadnt left or moved anything in there.Mystery. Anyhow my engine should be back in soon,and once run in back down to Emerald. As regards HGF...it wasn
t me and AFAIA no Simon Erland engines hafe suffered from it.
hope that clears things,
Jonny
Not everything written is a lie, and not everything is truth or fact.
Sadly for Simon Erland the facts are interlaced with bull, arrogance, outright lies, liable and misccommunicated second info.
I’m not perfect by any means, but I’m not claiming to be the saviour of the K series either, or trying to sell it to those with less technical knowledge as something that it was never desinged to be, a relaible 200+bhp race engine.
So when he preaches and I don’t agree I speak out and present my own experience. I do this for the benefit of others, not to discredit Erland. And to show an alternative apporach or to give credit to one that has been unfairly dismissed IMO.
I’m open with my postings and have given a [censored] load of info to the Elise community over the years, including you Uldis - remember you contacted me asking for advice, and you took it, trying longer trumpet lengths following our telephone conversations and chats at TT2005.
The post by Jonny could have been made for a number of reasons - I’ll let the reader work out what they may be. But given that the engine hasn’t been back for mapping perhpas Jonny is waiting (like so many poor souls) for it to be finished and doesn’t want to fall out with Simon. I heard of one chap had to have Elrand aquire him a residents parking permit for his car left at Erland’s for an Engine swap that took 12 months. He was fed up with paying the parking tickets.
As for what happened to my engine. The rods were bushed at a local engine builders and gudgeon pins were provided for fit.
I took some steel rods to Steve Smith (of Vibration Free) for balancing to be used with my tungsten inserted crank prior to building the 1.9k. He prefered my VHPD rods, being unimpressed with the weight of the steel ones. So I retained the VHPD rods that were used with the inserted crank in my previous 1.8 build.
The crank has been straightness and crack tested by Steve Smith and is fine for reuse. All the bearings were in very good condition showing that the modifications to the oil system made by DVA did their job, as did the sump baffle I had fitted in the wet sump. The three remaining liners were in perfect condition with NO evidence of blow by indicating that there was nothing wrong with the Scholar EVO2 block I was using, despite Erland’s opinions on the Scholar solutions.
I’m working with Dave Andrews and Steve Smith on the next build - two experts who’s experience and opions I value very highly.
