Well after six weeks away from the car I finally started on it again yesterday.
I have missed working on it, but have had a bit too much on my plate of late. Basically 2006 has not been good to the people around me. As I mentioned one of my very close friends nearly died in January after suffering several strokes. Well the day after he came out of hospital in the middle of February, my Nan was diagnosed with Cancer. She has to have radio therapy every day during the week, so I have been moving work stuff around so that I can take her as often as possible. She is 79 and very scared, my grandfather died about 6 years ago and she is all on her own. It�s really sad to see her not her usual happy self. Illness sucks man, I tell ya what we all take our health for granted, till it goes �Pete Tong�. I tell ya, my views on life have changed over the last few months!!!
Anyway back to the car.
The last time I worked on it I changed the fuel system a little bit. To be honest I had never been overly happy about the FSE fuel pressure regulator that Dave Walker fitted when the Jenveys went on. It just looks like a cheap and nasty bit of kit, plus it only has push fittings. The standard Jenvey fuel rail also only has push fittings and call me old fashioned but I�m not happy with dodgy push fit stuff when it comes to fuel and the chance of burning to death if something pops off!!
So I replaced the regulator for a pukka billet ally Aeromotive adjustable jobbie. These come with proper aeroquip screw fixings. I also called Jenvey and got them to send me a new one piece fuel rail, again with -6 screw fittings on each end.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/newfuelreg.jpg[/image]
When I was in Japan I saw a couple of cars that had blanked off one end of the fuel rail, making it look like there is no return. I think it looked really cool, plus it saves on about a four foot piece of -6 aeroquip pipe, so I went for that setup on my car. A prize to the first person that figures out how it all works. Lol.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/Newfuelrail.jpg[/image]
[image]http://img.photobucket.com/albums/0903/SeanBicknell/fuelregshowingtpiece.jpg[/image]
So that brings us up to yesterday.
After I modified the loom at home I connected it all up as I wanted to basically see if the car started, as I had kind of guessed a few things. Lol. So yesterday�s task was to start from the back and work forward making all of the wiring fit.
I mounted the ECU for the paddle shift for the gearbox on the rear bulk head as there are several adjustment knobs on it, so I wanted it in a pretty accessible place. Next I decided I wanted the engine ECU to mount on the floor just in front of the passenger seat. As it normally mounts on the bulkhead, none of the wires were long enough, so that entailed me cutting and extending every single ECU wire.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/Interiorwiringrear.jpg[/image]
[image]http://img.photobucket.com/albums/0903/SeanBicknell/RelocatedECU.jpg[/image]
I then made up all of the permanent wires for the fuel pumps, all of the gauges, the gearbox cooler pump etc. So they now all run nicely up the centre of the car and up behind the dash. I soldered all of the wires, but I ran out of the small size heat shrink, so the coiled up ones in the corner are waiting for some more to arrive tomorrow.
I am basically relocating all of the relays and the fusebox to the dash board, so that changing anything is quick and easy, however the hole on the rear underside of the dash wasn�t big enough for the fusebox to pass through, so out came the die grinder and the hole was made bigger. This ended up being a real mission as you are working in a very tight place.
Next up was refitting the dash board pieces, this was a real krypton factor job as it had been quite a few months since it had come out. It all came together though in the end and all of the wiring that is going to sit behind the dash is now all routed the correct way and is sitting on top of the dash.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/Dashbackin.jpg[/image]
[image]http://img.photobucket.com/albums/0903/SeanBicknell/dashwiring.jpg[/image]
A you can see from the picture above all of the wires that will sit behind the dash are a mile to long, so I reckon there is at least another day in shortening them all and getting everything to sit in the right place.
The other major spec change has been the electric water pump for the engine. Basically Simon (Erland) has recently rebuilt an engine that had done a season or so with an electric pump. He had the head tested for hardness and basically he reckoned it was scrap as it had gone really soft. So after a bit of a chat we have decided to revert back to a conventional water pump. I love trying new and different things, but I guess I don�t want to risk my engine and I especially don�t want to risk my new engine!!
So it was out with the electric water pump and in with a silicon 90 degree hose to replace it
[image]http://img.photobucket.com/albums/0903/SeanBicknell/Nomoreelectricpump.jpg[/image]
I obviously now had to also include a thermostat and put in some pipework to allow the water to still circulate when the thermostat was closed (basically taking the rad out of the picture.
So basically what I have done is put the remote stat back where it came from on the inside of the drivers side chassis leg where the water pipe passes through it.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/remotestat.jpg[/image]
I have then routed the circulation pipe round under the bottom pulley, basically following the routing of the oil cooler pipes and then bought it up and connected it to the old heater bypass return, that I had previously blanked off when the electric pump was fitted.
[image]http://img.photobucket.com/albums/0903/SeanBicknell/stattowaterpumphose.jpg[/image]
[image]http://img.photobucket.com/albums/0903/SeanBicknell/returntothermostathousing.jpg[/image]
The extra bits of hose have been put there to stop any rubbing when the engine moves about.
Today I haven�t touched the car as I have been preparing for a meeting I have tomorrow, well a meeting I did have until it was cancelled this afternoon. Mind you I finally got round to ordering the competition license starter pack from the MSA, I also joined the AMOC and I have filled in all of the registration forms for the MES series. The couple of girls I spoke to at AMOC were very helpful, which was nice. I also ordered my timing beacon from MTS, I didn�t realise they are configured to order which can take anything from a week to 28 days!!! The place is local to me so I went and hand delivered my order form in a hope of schmoozing a shorter delivery time.
Also ordered more heat shrink and a few other electrical bits and bobs. I ordered some carbon sheet to make my dash front panel out of and some heavy duty plasticy rubber stuff, to protect the bulkhead behind the front wheels as no one seems to run wheel arch liners in there race cars.
Tomorrow, now that I have a free day, will hopefully see some of the dash wiring shortened and looking a bit more like it should actually be there.
Sean…
