I haven’t looked to see how thick the metal is that the rivets go into, but i would have thought it would be to thin to tap a thread in it.
I’d have to agree - the metal is too thin to rely on just tappng it
Doesn’t the Exige sub frame already have threaded holes to accept the bracket?
I’m pretty sure it does.
Indeed it does.
Exiges have captive nuts already in the subframe ready for the brackets so it makes sense to use those
Might sound a stupid question - but where exactly are the captive nuts?
Just where they should be for the toe link bracket … assuming you have the right bracket
Glad to see I’m completely mad then
Please keep in mind… Stainless steel bolts (I mean the ones holding the actual toe-links) are relatively weak.
To give you an idea… I’ve helped someone out after the last Zandvoort trackday. He was complaining about a strange feeling in the rear. When I undid his toe link, I found the bolt to be completely stretched.
I’m not a fan of replacing suspension bolts with lower grade bolts. Stainless steel might be nice and shiny but it’s got a different characteristic then the original bolts, so you’re simply taking a risk!
Try a search on ‘toe-link’ going back over several years, there was much discussion on this a while back.
