Ok so I’ve got a soft top (thanks Gav ) Just need to get the rest of the bits. Has anyone got the part numbers I need to order? Or can point me in the right direction?
Also I’m not sure I want to do the cutting, don’t trust myself Can anyone recommend somewhere to do it? Or can someone do it for me? I’ll bring beer / beer tokens
Its with a guy now just having the two clips put into the rear roll bar cover (that’s all you need) So about £20 in parts and an hours labour. I only want it as a glorified/more secure shower cap, so I did try fitting the roof without this work done. It all goes on no problem you just can’t fit the support bars so it really sags in the middle. I should imagine if it rained if would gather water and stretch or even worse collapse. Conclusion: you definitely need to fit the support bars even if you don’t intend to drive with the soft top fitted.
I bought a soft top a few weeks ago and the conversion kit to fit it. I fitted mine at the weekend for exactly the same reason as you. I done the work myself though - measuring it several times to make sure before drilling/cutting. Can’t beat a bit of sunshine on you (on the rare occasions it appears up here).
Ooh . . . and . . . THEY’RE OFF . . . the odds-on favourite, Pesky, is first out of the starting gate with Tim closing on the rails . . . AndyD comes into contention from a long way off but Thommo is keeping a watch brief but looks like he may stage a late challenge . . .
