Hi Guys due to ‘other’ mods (all will come clear soon)
I Have a
Pipercross Vector Induction kit for sale
[image]http://i6.photobucket.com/albums/y201/jamieall/lotus_exige_vis_location_640.jpg[/image]
The marketing stuff…
The Velocity intake system is designed to maximize the torque and power produced by your engine.
While the bhp gain is important, this system’s tuned length, similar to the tuned length of a performance exhaust, will give a broader power band. Giving you increased power, over a greater length of the time. This tuned length of carbon fibre also relocates the air filter into an area of cold air. The cooler dense air carries more oxygen to you engine, more oxygen mixed with more fuel will give a reliable increase in power.
This intake utilises the Pipercross Vector power cone with a unique foam make up, using the same technology in Formula 1 and the World Rally Championship, Maximises air flow with the ultimate engine protection.
The carbon fibre pipe made from Aerospace quality pre-impregnated carbon fibre, that incorporates a proprietary thermal barrier layer in its construction. The system’s use of various fibre composites is geared specifically towards keeping the INSIDE of the intake tract as cool as possible.
Compared to the original air box, the V.I.S kit shows increased air velocity of over 40%. The V.I.S dynamics are a great improvement on the stock system, thanks to a specially textured inlet surface, that results in better throttle response and drivability.
In other words its a cold air intake taking cool air from the side scoop instead of hot engine bay air. makes a great ssssssssss noise on cold start up and Grrrrrrr on full acceleration. Nuts on 2nd cam quiet on part throttle
Been on car for the last year.
�125
And
A High flow sports modulor cat from 2bular with a rating of 375hp!
It has been on the car for under two months
Included is also a bypass pipe which is just bolt in bolt out!
[image]http://i6.photobucket.com/albums/y201/jamieall/2bular111RSpohheatwrap.jpg[/image]
RRP �440
�320
