More photos on Pistonheads. Clicky
First registered in Dec 2000 this car comes complete with documented service history from Lotus Cars, Lakeside Engineering and more recently JSRacing.
Two weeks ago the car was fully checked over and full service carried out including cam belt and tensioner and brake fluid change with Castrol SRF at JSRacing.
12 Months MOT
ENGINE
1800cc VHPD fully rebuilt 6000mls ago. Including DVA ported head, Piper 1444 cams, verniers, Colsibro guides, Omega Pistons, PRT, Emerald ECU, Magnecor 8mm plug leads, Lotus Carbon Air Box, Mocal Oil Catch Tank, Front mounted oil cooler etc full details on request.
Engine produced 215BHP on Dave Walkers Dyno at Emerald.
Current mileage 50,000mls
GEARBOX
Light weight flywheel
AP Clutch kit
Redline MT-90 gear oil
EXHAUST
Piper manifold
5" SCRP (Elise Parts)
Lotuspower spec exhaust
SUSPENSION
Nitron single way shocks
Adjustable ARB
Full Geo check/adjust at Guglielmi Motorsport
BRAKES
290mm Ali Belled front brakes standard rears
Stainless Goodridge hose kit
Brand new front and rear Performance Friction 97 pads
EXTERIOR
Bodywork is in excellent condition but with the usual stonechips to the front clam. Regularly detailed using clay bar, Chemical Guys Polish, Jetseal 109 and Two layers of 3x Carnauba paste wax.
Motorsport Engine cover (the original perspex engine cover is included)
Carbon Side Scoops
Lotuspower front splitter
Lotuspower rear diffuser (the original diffuser is included)
INTERIOR
Lotus Motorsport Carbon door cards
Lotus Motorsport Carbon handbrake cover and gearlever cover
Reverie Mulsanne B single skin seats with Novasuede seat cushion kit
Harness Bar with Safety Devices 4pt harnesses
FEV FX G-TEC Electronic plumbed-in fire extinguisher system with internal and external cut off switches
Cartec battery isolator with internal and external cut off switches
Alpine head unit
This car is maintained regardless of cost and has recently had Fuel pipes and fuel pump/sender and filler neck hoses replaced and oil cooler pipes replaced due to age to ensure the car is reliable as possible
The private plate as been removed from the car.
Certificate of Conformity from Lotus is included with the car.
�24,950
