Rebuilding my CUP260
i went for 308’s all round so hoping by what youve said the balance should be ok, maybe a little rear heavy, but hopefully that will be conpensated by the much heavier audi engine in the back.
315 front 295 rear here, given that most people are putting proportioning valves in the rear lines I didn’t wanna go OTT on the back
You can’t put proportioning valves on the ABS cars sadly, you can def go bigger than 295, but then you run into handbrake issues
I did have 315mm front 308mm rear for a while with knackered rear discs and the balance was fine. Long term I might well take off the 315 off the back and put on some 308 to give a spare pair of fronts :slight_smile:
https://www.motorsportauctions.com/index.php?a=ap&addon=storefront&page=home&store=710&listing=33889
That would have done the job, didn’t know they made them.
Here is
We have those in our Caterhams, work a treat and properly easy to adjust whilst on track.
If it’s an issue being a Frank fan boy I can delete this post :wink: :smiley:
I finally
loving the choice of fittings
so how long do they give you on the tank before it needs re-certing?
5 years…
cool, thanks for sharing.
So does the clock start from when it’s made, or when it’s first wet?
The date
Lots of things
yeah so lotus had a load for sale, but they must be useless by now
yeah so
Ah left over from the R-GT project? What date did they have on them?
I also got
:lolno: :lolno: :clap:
Nice work on the scanning, will be very interested to see where you get to on it and how closely the calculated matches the flow bench.
How come you choose a rotrex? Considering all other over the top updates to maximize output
