The last days, I�ve done some work with the electrics�
First of all, the main parts I used/will use are:
The heat shields and shrink tubes:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00253.jpg[/image]
Braided cable protection:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00254.jpg[/image]
The wires (mil spec):
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00252.jpg[/image]
Connectors, plugs, (some) switches
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00251.jpg[/image]
And the circuit breakers:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00250.jpg[/image]
I�ve started with the engine wiring, which looked like this:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00255.jpg[/image]
Notice the length, which is extended as I used to have the ECU next to the driver.
I�ve stripped it down�
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00256.jpg[/image]
until:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00257.jpg[/image]
Then I replaced some cables, extended/shorten some others, changed a few things and removed anything that is not used:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00258.jpg[/image]
Then I crimped all the cables to the pins of the connector:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00282.jpg[/image]
I�ve inserted a pin into the other half of the connector and tested by moving the cable around a few times the strength of this crimping connection. It had to be very strong in order to resist the vibration when installed in the car. Unfortunately, it just popped off�
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC00283.jpg[/image]
So, I decided not to use these connectors at all. I soldered the cables of the ECU connector to the rest of the harness, opened a hole at the aluminium bulkhead and just used a suitable rubber grommet.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/SOON_wiring1.jpg[/image]
Now the engine wiring harness is on the car, and hopefully is working as it should do!
Tomorrow I�ll start with the vehicle main wiring harness� That will be fan�
