As promised…
I�ve been an Elise owner for the last 3 years.
Here is a photo of the almost standard car.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/1.jpg[/image]
Before four months I�ve decided to convert the car to a race Exige.
First job was to strip it down:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/2.jpg[/image]
In the above pic you can probably see the mount for the steering colounm in the centre�
I tried to make the car as light as possible removing anything that is not 100% necessary, including the aluminium tubes for the heater. I also removed the battery cables that run inside the sill, as the battery will be place inside the cabin. Finally, the S/S braided hose for the clutch removed too, as I preferred to use solid tube for it, running inside the cabin next to the brake line.
I had the picture of a M/S Elise in mind, so started looking for body parts (a few of you probably remember my �wanted� posts).
The first thing I�ve installed was the aluminium fuel tank.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/3.jpg[/image]
You might notice the Kevlar braided hoses. I preferred these from the usual S/S braided ones as they are much lighter and resist to higher temperatures.
The roll cage and bulk head was the next task. I admit not an easy one�
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/4.jpg[/image]
For the brakes I replaced the master cylinder with two separate ones. I am not sure if the bores are correct, as I might have to change them after I find and install the front brake system. The installation of the master cylinders and the mechanical brake bias in the original brake pedal was a pita, but now it seems that it is working ok. I�ve also connected a remote knob to adjust the bias easier. A 90 degrees coupler was required for this reason. New brake tubes all around had to be done, too.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/13.jpg[/image]
Then I installed the QED dry sump kit, which was easier than I was expecting. At the same time I replaced the cam belt.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/5.jpg[/image]
Then the engine was back on. By the way, the engine for this year is a standard VVC one with 340R throttle bodies running with an Emerald ECU. In the very near future I will install a big bore janspeed exhaust manifold. I decided not to do anything more to the engine for this year. At least I am very pleased by the gearbox, which is a 5 speed Quaife one with straight cut gears.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/6a.jpg[/image]
Impressed by the room between the engine and the new bulkhead!
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/7.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/8.jpg[/image]
The oil pump:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/6.jpg[/image]
I had the ECU mapped before I stripped it in Emerald. Unfortunately, the VVC mechanism stopped working at that day, but these guys in Emerald did what ever possible to map it even the faulty VVC mechanism. I had to pick up the car with my trailer, but I when I got home and replaced the VVC mechanism the engine was working perfectly!
Here is the power-torque graph of the engine:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/17.jpg[/image]
I know it does not seem powerful, but hopefully with the working VVC mechanism will be much much better.
Forgot to mention that I decided to change the colour from silver to black� A lot of preparation for the sills and all the rest body parts, but unfortunately the result is not what I was expecting! But I do not complain as I knew that I am not good in painting. I will try to improve it as soon as I finish with everything else.
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/10.jpg[/image]
You can also see the holes I cut in order to remove everything �useless� from inside.
About the body parts� I bought a cheap but old � rear panel which required a lot of work in order to be again like new, a new plastic windscreen, front spoiler, side sills, front splitter, loads of tyres, a new � rear panel for the other side, engine cover and many other bits in very good prices. I also managed to find and bought a set of Exige original wheels, plus a good set of wet tyres. I will be looking of at least one more set of wheels as soon as I finish with the car�
Maddog delivered to me the front clam and roof, so the body was complete. It was just a matter of fitting everything.
Maddog�s roof:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/16.jpg[/image]
Again the roof with the front clam on it!
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/12.jpg[/image]
The oil and water tanks can be seen in this photo, too. Behind the oil tank, on the bulkhead I�ve placed the fuel filter.
I�ve cleaned all the suspension parts, painted them and put them back on. I removed the nylatron bushes (I was pretty disappointed with them as they add too much friction) and replaced them with spherical bearings. It is pretty amassing how easy you can move the suspension assembly (without the damper). I can do it easily with my small finger! Of course the installation wasn�t a one hour job�
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/14.jpg[/image]
I wish I had more photos of the �project�, but I never thought about this. At least I have a few!
One of the latest I have (three weeks old):
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/11.jpg[/image]
Since then, I�ve installed the rear M/S 295 mm discs, put the rear clam and roof on and managed to connect them. The radiator is also on and so is the front clam. One of the following days I have to order some new fittings in order to complete the fuel, oil and brake lines.
I hope some of you will find something interested in this post so I can share with you the enjoyment of this project. As you can probably imagine, I rather take my time and build a nice car than rush and go and drive it.
