Yellow Frank??? Did you used to drive it wearing a skirt??
In all fairness, its very very cool. I love RS200ās
Yepā¦neither of them have written a book!
I have no Idea what that means but fuck it donāt take my advice after all itās free.
I always enjoy saying I told ya soā¦
or a Scuffers on steroidsā¦
Now Scuffie and I get along and share mutual respect for each others accomplishments rather than the guys that just regurgitate hypothetical BS only to be proven wrongā¦
One of these days Iāll get my high school diploma and become an engineerā¦nahh
Frank, everyone has respect for what you have done, theres no doubt about it.
We would have been happy to fit one pump, but advice from the manufacturer of the pumps, and having run this set up for 4 years or so, suggests weāre not too far away. Yes, we may be able to get away with one, but modifying the tank to take 2 at a later stage, is far more expensive than building it with 2 at the outset. Would be happy to be proved wrong, but not brave enough to turn one off and find out that its not.
Dudes have a look here and read the fine print⦠http://store.radiumauto.com/index.php?p=product&id=51&parent=0
These guys make a great product and test each and every bitā¦
I totally forgot to mention the 255 Walbro in tank feeder pump on my setup so that could be the reason there is no fuel supply issue with my carā¦
Still the single feed pressure/volume is more than enough to support the power to 600⦠:whistle:
But ya gotta keep it coolā¦
Cool man. Have seen similar items in a couple of places now. Even have one on my desk.
Iāll forward it onto Bosch and let them know that they have been doing it wrong all these years
In the meantime, lets agree to disagree on this one
They could use the help since they havenāt done any testing on a Lotus or did Lotus for that matter since the tank design has been an issue from day oneā¦
Iām not arguing with anyone, Iām just letting ya know what works for me⦠If ya gonna build a race car you design systems for quick on site service you donāt hide them under shear panels and undertraysā¦
We have to toss out diferent ideas to each other, that how progress is made. There is no one way to do anything but there is a right wayā¦
Now, THAT, I agree with. If only someone in the Lotus road car design office understood this principleā¦
Snap, however its gotta go somewhere, and neither are race cars. Iām pretty sure that every car manufacturer has a bastard department. Otherwise perfectly servicable designs go off there, only to have some small item located across it, just so that changing the 20p widget takes several hours!
Iāve run cars with 044ās for far too long, and can probably count on one hand how many failures Iāve had. With probably half of those casused by crud in the tank being sucked up, incorrect positioning or constantly draining the tank and running the pump dry. Weāre confident with where they are and what they are doing, and if they constantly need changing, youāll hear it here first.
Far happier than running one,- and please donāt take this the wrong way Frank - ācos Frank said itāll be fineā
Now where is the pre-pump filter and is there a check valve at each pump discharge just incase�
So to replace a fuel pump you now have to remove the chargecooler and what ever bits are covering the shift cables to remove them before you can remove the shear panel to get to the pumpsā¦Isnāt this funā¦?
Iām just trowin this crap out there from experience⦠:whistle:
I canāt wait to meet you guysā¦The line forms to the right, itās one at a time and bare knucklesā¦Iām old
[quote=frank]Now where is the pre-pump filter and is there a check valve at each pump discharge just incaseā¦? Pre pump filter in tank. Non return valve fitted to the end the of pump as normal, not sure about a check valve, Iām thinking this is a US to UK english thing?? The only check valves I can think of in the fuel system were way back in on the old K Jetronic systems??
So to replace a fuel pump you now have to remove the chargecooler - no - and what ever bits are covering the shift cables to remove them - none - before you can remove the shear panel to get to the pumpsā¦Isnāt this funā¦? Not sure why you want to remove the gear cables, as the tank stays in to get to the pumps, release bolts and slide to the side. Easier than the OE ones.
I canāt wait to meet you guysā¦The line forms to the right, itās one at a time and bare knucklesā¦Iām old - Iāll be the one carrying you a beer
See above. Any more, but getting a little bored now Iām sure we can all poke holes in other peoples work if we felt the need to.
Oh come on now Iām not pokin holes, I hope you know that.
Iām tossin out the bits of information Iāve learned over the years from my past screw ups and there have been quite a fewā¦
You donāt think I Helicoiled most threaded holes in my setup because the bits had to come off and on so many times for fun do you ?
R$D is funā¦Repairs suckā¦
Can you post up a pic of the engine lay out, the only Audi setup Iāve seen has been the Pro-Alloy S1ā¦?
Will if you promise to play nice!!
But not for a day or two though. Customer coming to see it thursday since its just been painted, and he gets to see it first. Only fair.
Duhhh come on I wonāt tellā¦
Dide you remove the boot wall for easy access like Wayne and I did.?
I bet that customer is getting quite excited
[quote=Benja]
I bet that customer is getting quite excited [/quote]
& be glad to ditch his Fiat.
