I’m looking at a Elise with a honda swap (done in 2008) by Phoenix Motorsports, and while I read plenty of good things about the garage the details on the kit they use can be vague.
Anyone here got any 1st hand experience? Anything to look into?
I’ve had a Pheonix N/A Honda’d Elise S1 now for 2 1/2 years 30,000 miles and had little or no problems with it that wouldnt occur with any other car a wheel bearing failure, a couple of ball joints and a CV boot split after 24,000 miles in my ownership which I replaced with a Holfmans one
The only problem I did have was the O/S Engine mount which cracked and broke twice both times the mount was replaced FOC all be it taking a while ~ down to the manufactor of the engine mount’s not Pheonix , the second mount was strengthened and slightly differant design to get rid of the square bolt holes which stress fractured across the corners and broke dropping the engine onto the under tray
The engine was re mapped from the early origional map which had a wee flat spot in it ~ according to a couple of other Pheonix converted car owners I know
Interesting, mines done about the same milage over the last 2 years, will have a look at the engine mount. Assume it’s a fairly easy DIY fix, drop the trays and support the engine from below before swapping the mount.
drop the trays and support the engine from below, remove OS wheel and wheel arch liner to allow engine mount access from under the OS wheel arch
No need to remove the drive belt unless it needs replacing
cheers Hamish
So just the drivers side mount needs doing, might see if I can get one as I need to drop the trays to reset the exhaust and fix a tinkly rattle from some kinda clip at 2300rpm.
Had a mate of mine who’s a mech eng by trade and who said “yeah square holes will cause fatigue spots, round em off or get one with square holes”
Had my Phoenix conversion for over 3 years now, and I’ve never had any maor issues with it
I just need to uprate the manifold as I’m still on the standard Honda manifold that comes with the install, and I’m told it strangles the engine slightly
Good to know, mine was done in 2008 but I’ve owned it for just over a month.
Exhaust has shifted slight, causing the downpipe to touch the diffuser, melting a small hole and making a buzz. However realigned it at the weekend, and cut a small hole in the diffuser to clear the DP.
Plan is to go see Chris Tullett for a new manifold, maybe we should do a group thing with other Pheonix cars as the design will be the same. Miles?
[quote=MilesH]Had my Phoenix conversion for over 3 years now, and I’ve never had any maor issues with it
I just need to uprate the manifold as I’m still on the standard Honda manifold that comes with the install, and I’m told it strangles the engine slightly [/quote]
My NA Pheonix Elise still has the original cut and shut manifold but when Tdi had it to map it then later to put in a cold start map they told me it had 205bhp at the hubs and was one of the better they had seen, are you sure your car’s not on the original Pheonix map the early ones apparantly had a flat spot on them ?
Lets face it Honda must have spent $$$$ thousands designing the original cast manifold for the engine so I doubt it would be that bad although it did use a much higher Vtec point than most Honda ElisesExiges
