[quote=JDS][quote=IanM][quote=Podger]An update on the Carbon Lorraine pads …they HAD NOT DELAMINATED, but had rusted to the face of the disc.I had been for a 20 mile drive in the car, roads were slightly damp, got home , left the car on the drive for a few hours, then garaged it. Two weeks later, went to move it , to wash the car, and the front wheel locked. Had I known what the problem was before removing the front wheel, and trying to free the pad with a screwdriver, I had to break the pad up to release it. I could/should have put the car on the road surface and done a Hillclimb start, but at the time, the wheel was just skidding on my garage floor in reverse.
Now Mintex pads fitted , but it’s quite clear the CL’s did not delaminate , but because they have such a high metal content , rusting to the disc was the issue
I know that this has happened to other’s on here , who wern’t running CL’s.
Just needed to clarify the exact position. [/quote]
Performance Friction have done this on mine, [/quote]
Interesting on the PF comment, although which bit?
Nearly all pads will leave a mark on a disc when left, hot, cold, wet or dry, if you have a certain set of circumstances. Blame the EU for making pad manufacturers take out all the stuff that made them work really well. You know, lead, asbestos that sort of stuff. Apparently its bad for you.
I ended up caught out on damp roads so when I put my car away there must have been some moisture on the disc, the rears “welded” up solid just as CL’s have done. They have not delaminated as some have described CL’s but the are a couple of small patches of pad material missing off a couple of edges of the pad, very small and nothing major and fine still to use but there was a nice imprint of the pads on the discs. PF97’s that you sold me on standard rears.
