New Wiper Blades
Hello can someone please advice where to get a new windscreen wiper for Exige S2 that gives a good sweep across the windscreen. I have replaced the wiper blade and the wiper arm as I though that might be the problem, but it hasn�t fixed the problem. If anything it has gotten slightly worse and is now noisy.
PIAA Silicon wiper from demon tweaks not cheap but they are awesome. Get a plain one with no spoiler though and not the curved one :wink:
Winged blade from auobulbs direct or a bosch one from halfords, any other blades I’ve tried have been naff or only been any good for a few weeks.
Thanks for your responses i have just bought a set of PIAA Silicon wipers.
what size (in inchs) PIAA silicon wiper blade did you buy to fit the car?
You won’t regret it we’re on our 3rd wiper and they’re awesome :wink:
I pretty I’m using a 24" one :slight_smile:
thanks orangeD
good article on the seloc techwiki (dont have to be a member)
Just got one from Demon Tweaks , it seems a bit shorter and I can’t get it to fit , what adapter do I use ?
Does your wiper arm have a hook on the end?
Done it ! Had a coffee and a cig , kicked a few things and came back to it , it was on in 30 secs , I must have been having a moment :crazy:
Glad to here you got it sorted :slight_smile:
Good advise on this thread as I’m in need of a blade as well :slight_smile:
One question, are the PIAA Silicon blades only available at Demon Tweaks, or can you buy them from places like Halfords?
They are a bit specialist so yes DT or the like is your best bet :wink:
Just to confirm, this one:
http://www.demon-tweeks.co.uk/Performance/Windscreen_Wipers_&_Kits/Wiper_Blades/PIAA_Silicone_Wiper_Blades/549/3173
I need 24", no spoiler and not curved.
Will that fit my Exige? Just want to make sure before I order one.
Cheers :slight_smile:
Yup that’s the one :wink:
Thanks! I’ll order one now :slight_smile:
Right my new blade has turned up. Now I’m not that technical when it comes to fitting bits to my car so can I just ask which adapter size you used when fitting the blade? There appears to be adapters called C1 to C6.
Cheers!
I’ll have a look when I get home :wink:
