New Prototype upgraded Clutch Bracket
[image]http://www.maddogmotorsport.com/photos/ClutchBracket.jpg[/image]
did I mention it weighs 5/8ths of nothing and is made from marine aluminium
what do you think
what do you think
Will it float then?
might be handy if you get gerrards wrong
Is that for the engine side?
Stiffer?
Quoted from Elise-shop
“This product will prevent the bracket of the clutch slave cylinder to flex and evantually to break…
We would suggest to ask someone to sit inside your car and depress the clutch while you are looking at the slave cylinder which is fitted on the gearbox. You will see quite some movement in the bracket! This flex will slowly cause the bracket to fracture, but even more annoying, it will reduce the pressure on the clutch cylinder arm. This will result in slower gearchanges and in crunched gears.
This easy to fit bracket will fit between the clutch slave cylinder support and the engine and will remove all above mentioned flex from the system.”
Ok, so it’s the same function as the Eliseparts one.
I was looking to get one of those but like yours better!
Tell me when you’re finally making them, I’m up for one.
maddog
i like the look of it as well… what kind of money in them?
I’d heard the Eliseparts one wasn’t the most accurate of fits. Any comments?
This is the Eliseparts one:
[image]http://www.eliseparts.com/shop/images/large/Clutch-strengthener-bracket_LRG.jpg[/image]
and this is the pic on the Elise-shop website:
[image]http://www.elise-shop.com/images/ALTBRACKLOW.jpg[/image]
Yours certainly looks a well thought out design.
thanks guys, will have confirmed prices on monday
Monday??? What the bloody hell are you doing all weekend then???
Was going to do the wishbones today but it’s pi55ing down
junks
what were you going to do with the wishbones ?
I am waiting for other people to get back to me on prices,
Waiting for other people its the story of my life at the moment
Finally! I got a price today
they work out at �45 plus postage
is it a simple bolt off the old part and replace with this one?
Anodized I assume (or is that extra?)
Is that marine grade 5083 Aluminium alloy - “the very same material that is used to build sea going RNLI vessels, with a proven lifespan of over 100 years, marine grade aluminium is extremely resistant to corrosion”
yes, made from the same material
