Are they easy to fit, I was looking at the forge one but it said not recommended if you had only one strut that holds the boot up…??
Mine fitted with a single strut just…
A bit more dirty filthy carbon , drilled a 70mm hole for the aeroduct and lined the edges of The hole with rubber strip. I’m chuffed how it looks .
Brilliant this was what I was going to do over the winter too. Did not know you buy the shroud from RLS
by the way who are RLS can’t find anything
appreciate a web address or phone no.
Nice job by the way
[quote=scoob] who are RLS can’t find anything
Nice job by the way [/quote]
Really Light Stuff
My carbon scoops have arrived from them and the smaller pulley. The service was very good
Prepare to be stung by import duty
Paul, (Moomin) may have a spare 3 way carbon shroud???
the carbon bits looks very tasty…very clean setup indeed…
thanks 661 I’ve sent a message to moomin, fingers crossed
Now that you have blocked most of your engine cooling air you should check the surface temps of your intake manifold…You should have a spare Alt waiting on the shelf because you will be needing it. :whistle:
If removing just the mesh screen can lower temps 10-15*f think how much hotter things will be when warm weather returns ?
I don’t know why guys buy this junk from fools…
Lol a bit harsh frank , bad day ?! The carbon side covers are short and won’t block any air coming in . I have wider side scoops so more air flow than standard.
Junk ?
I ended up using the carbon one , sorry mate !
How much weight did this ADD!
There are some old threads [a few years back] here about guys doing just what you’ve done with predictable results… Higher engine temps and toasted alternators…
I don’t mean to be harsh but guys need to check to see what has been tried and tested by real Lotus racers and nut jobs before spending hard earned coin on a fools folly.
I hate to see BS being sold…
Frank knows his stuff, & speaks wisely…albeit in his own inimitable style
I would say about the same as the standard setup with the lightweight tubes ,oh and all the fixings I replaced with sexy titanium ones.
Mmmm , little monkeys !
You might be able to cool off an I/Phone with those fans but to cool off a constantly heated intercooled you are dreamin of fighting windmills…sorry dude but I would try for a full refund or an exchange for a cup holder…
Nope not for the intercooler !
No worries moomin, thanks for the reply, think I might have a go at altering the stock shroud, as planned, already sourced all the bits from Merlin at Castle Combe, I’ll let you know how I get on
how many guesses do we get??
