New, beltless Honda K20/K24 dry sump system/group buy‏
Afternoon all.
I thought I’d start a thread about a new project which we’ve spent the last 8 months or so trying to get going. It came about due to my Time Attack car needing a proper Honda K20 dry sump system and no current off-the-shelf systems being quite what we wanted. Mainly due to packaging reasons. Therefore we approached AT Power, a UK company who are starting to specialise in a new wave of dry sump systems and who have plenty of previous experience with the Honda K20. In fact, they already make a normal style K20 dry sump system. Added to this, they also have the benefit of being able to produce their own pumps.
So, rather than following the norm this new K20/K24 concept involves driving the pump internally, therefore ending the need for the crank/pump pulley and drive belt. With this in mind it also seemed appropriate that the pump should be mounted directly onto the sump pan with the scavenge ports running through the pan itself and directly into the pump. This removes the need for so much pipe work/fittings under the pan and should also reduce potential leak paths, whilst at the same time saving on plumbing costs.
It’s planned for the system to use four stages. One for the pressure stage, two for scavenging from the pan itself and another scavenging internally, directly from the head.
There will also be provision for a turbo oil drain, by building a feed into one of the scavenge galleries.
Pressure/return ports will be positioned to allow for the shortest possible pipe runs (i.e intake/gearbox side)
Turbo drain/scavenge port machined into pan.
Built-in adjustable pressure relief/valve.
So, a few details about the pumps themselves:- (Final pump spec/flow rate/gearing to be finalised after testing)
Machined from billet & not cast.
Dual-ported to aid rotor fill at high rpm and deliver a more stable oil flow sooner & for longer.
Stages dowelled for true alignment.
Bearings at front & rear of the shaft.
ARP fasteners used throughout the pump.
Common female inlet/outlet port threads.
The sump pans will also be machined from billet aluminium.
I’ve put up a picture of their latest Evo system drawing and prototype to try and give a taster of what AT Power’s ability is. The K20 would not be able to work like this image as the chain for it will not allow it to be driven to far outside of the silhouette of the skirt of the block. This means that in comparison, the pan may grow a little in depth due to housing the pump although it is still expected to end up around 1/3 shallower than the standard pan.
The technical drawings for this system are being produced at the moment and should be finished by the end of the month. Then once the design has been signed off, a fully functional prototype will be machined and built up, ready for some vigorous testing, both on the bench and on track.
I’ll be fitting one of these systems to my car but I’m also trying to see if anyone else is interested. If enough people potentially want a kit, then there may be the option of doing some sort of group buy. I already have a small list a people but could do with getting a better idea of overall numbers to see what sort of deal I can arrange. So if anyone is interested, please send me a message with some contact details so that I can keep you informed about progress. On a side note, we’ll most probably be working with ProAlloy to make us an oil tank to use with this system. However, this will be a tank with a difference and I’ll hopefully be able to provide info about this too in due course, as the kits will not come with any pipework or oil tanks.
At this point it’s probably worth mentioning that I have absolutely no financial involvement with AT Power with regards to this project. I have nothing to gain from it (financially) apart from ending up with a suitable system that’s available for me to buy!
Well I think that’s about for now, but I’ll try and keep this thread up to date with any additional info I get.
Thanks for reading.
Jamie
Nice work Jamie!!
Tempted, but I’m sure Darren can make our own :wink:
See what Darren says then? We could have made our own too. However, it’s far simpler to let a dry sump specialist do what they’re good at, have repeatability, off the shelf parts and make them available to others. Plus, doing a one-off wouldn’t exactly be a cheap excersise anyway.
Credit to you Jamie for continuing to push the envelope.
You still on track for getting the car out for next year bud?
Cheers buddy. Well as always, my plans don’t always pan out time-wise!!! The car is in exactly the same state I left it in about 6 months ago :frowning: However, behind the scenes we’ve been working out how to re-do everything, making parts, ordering parts, commissioning parts, so not all is lost. Once we have all that, putting it back together is really the easy bit I suppose.
The problem is still funding the rebuild, along with time, but I do hope to have it back together very late or earlyish next year. This means that next year will be a relaxed year of testing with maybe the odd round of Time Attack if we’re 100% ready to go.
Finally an update with regards the dry sump project!!
Now before anyone passes comment on any specific design elements, this is not the finished article yet and a few changes are still being made. This is just a little teaser for those of you who are interested and purely shows the outside of the system from above and below. Having just spoken to AT Power, the plan is to get the drawings totally finished by the end of next week at which point I can show some more in-depth parts of the design and inner workings.
So a couple of things to mention:-
-This drawing doesn’t yet show a turbo oil drain.
-It has also been decided that there is going to be no direct-from-head scavenge. It’s something that is quite complicated to build into the system and more importantly something which could potentially cause issues.
-Oil inlet and outlet locations are not finalised yet.
Oh that’s a beaut
Right, a few details have been changed now and locations of things finalised. Now the drawings just need to be tidied up a bit.
-So we now have a turbo oil drain on the exhaust side in the top, green section of the pan.
-We have ‘Oil in’ on the inlet side, set in from the end slightly.
-We have a choice of ‘Oil out’ on either inlet or exhaust side and a blanking plug will be supplied for whichever port isn’t being used.
-We have the PRV on the inlet side now and not sticking out of the side.
Once the drawings have been cleaned up and signed off, then I’ll post up pictures of the internal sections etc. I’ll also put up a detailed description of how it’ll work. Enjoy:-
If anyone has any views on it, then please feel free to comment.
Last pic:-
And we’re done…well almost!!! I’m very, very pleased to say that the first AT Power Integrated Honda K20 dry sump system is finished. And what a beautiful piece of engineering it is.
This prototype kit has been completely dry-assembled to check for operation and fit. All is good and it’s now been pulled apart again and sent off for anodising. By the end of the week all the parts will be back again and bolted together, just in time for some testing next week. We cannot wait to see how it performs.
Better pics to follow once it’s back together and anodised.
looks awesome!
whats the plan for testing?
Well done Jamie looks awesome :sunglasses:
Do you have a rough plan for the car? Are we gonna see you out next year?
yeah does look mint
Well for the moment, we’re just going to run it on an engine dyno for a day. Hopefully next week providing I can get hold of a Hondata K-Pro ECU which I’m struggling with right now! You haven’t got one I can borrow have you??
Providing it works well on the dyno and gives us the figures we need, then it’s basically ready to go. All of the pump parts etc for this system are a known entity due to them being the same component parts as used in all of AT Powers pumps. And AT Power know all about the life of those parts. And due to the design and layout of the scavenge etc, if it gives us the right figures on the dyno, then it will work without fail on track.
I’m going to see if we can get one on a car at some point though as it would be a good thing to do anyway.
Yes, I’ve always had plans. It’s just following them through that’s the problem. Not enough time or money right now, so god knows if it’ll get built next year?
I have the AEM ecu that was in the car available if thats of any use?
Also happy to use car for final check if you want, we did the same thing last year after fitting the ARE dry sump and used the Syvecs to monitor pressure and go to safe mode if it saw something it didn’t like. (car has Vbox so can give you realtime footage with oil pressure overlay)
Thanks for the offer but I’m not sure I’d be able to link your AEM ecu onto the standard loom I’m using for the test. Do you have a patch loom for it to go onto a standard loom?
Regarding some dry sump testing, that would be great if you’re really interested and want a system. I may be able to sort out a slightly better deal on a kit than I’m already getting too. Just let me know.
PM coming your way :slight_smile:
Anodised, built back up and ready to go. It really is a stunning looking thing now!! I’m so chuffed with it.
