Mini update, started work on making the manifold finally.
After alot of thinking and trial and error ive come to the conclusion that making a manifold for an s1 exige is actually very easy, only need a little bit of short straight and eight 90* bends
Its short, simple and will mean the turbo will be centered(the image shows where the actual turbo will sit) and easy to get access to.
The turbo will sit above the head with the downpipe going over the gearbox and then dropping down to the exhaust outlet.
Also popped over to demon tweeks with my mate so he could buy some stuff, while there I bought a couple of tow straps(one front, one rear) hopefully ill never need to use them.
i didnt want to use the stock front towbar because its heavy and it rusts, so ive removed it, I did look at the stainless version, but again its weight I dont want to carry.
Ive worked out how to mount the front using the 3 holes in the top of the crash structure(one off the old towbar) and 2 extra ive added for the splitter tie bar, ill use a piece of spare 5mm ali bar between those 3 holes with the towstrap in the middle one which will help spread the load if it does need towing out…simple and lightweight
The rear I wont know yet until I put the rear clam back on, put im hoping a longeron is in the right position
Just bought my wheels today
16x8 et 20 fronts and 16x9 et15 rears, so fairly extreme.
on the fronts ill be running 20mm hub adapters from 95.25 to 108 and on the rear 25mm adapters from to either 100 or 108 depending on the studs.
so the fronts will stick out 20mm more than exige wheels and the rears will stick out 21mm more than exige wheels, but ill be running alot more camber than a stock exige so my calcs say with will be just about ok.
In an ideal world I would only be running 15mm adapters on the front but they cant be made that small, I have wondered about having the inside face of the wheel machined to take off 5mm but not sure where to take it to for them to do it as even though theres alot of meat on them, some places might be concerned about doing it.
the reason for the width is im running 225s on the front and 265s on the rear, this should balance the car out compared to 245s rear and allow a massive amount of grip
