pinched some bits and bobs off seloc to update this, the car weighs 702kg with no fuel and I know of at least 35kg that can come off it.
I have to order a EP Lightweight engine mount and an adjustable lower mount aswell so calm my engine movement down so ill get some at the same time.
Got it home tonight after new exhaust, on idle it seems the same as before, on full throttle it sounds awesome, proper k series angry sound, dont think it will pass on drivebys but luckily I can adjust the angle of the tailpipe away from the sensors now, plus I have an extra external bolt on muffler for track days, you would say the same at time attack but actually listening to the cars there, there is no way they are only 105db on full boost, some of them you can hear on the other side of the circuit.
Here are a couple of pics
I tried to make a box to contain the ecu but in the end it was just a pain in the arse, so I decided to fit it to the carbon panel with velcro, its lightweight, acts as a dampener against vibrations and is easy to get to, i then velcro’d the relay box and map sensor onto the ecu.
We had to trim the panel to make the box fit as its set at an angle to be able to reach the clam outlet, I still have to remove all the inner part of the exhaust area which will also give me more room around the exhaust.
I have a little straight piece for when im on the road, but wanted to try the elbow to see how it fits, looks a bit weird but i suppose I wont be using it much, my girlfriend said it looks like a rats tail and now is calling it a rat car
Pretty close to straight through the system, will be interesting if there are any gains on the dyno
Put my rear lights and wiring in, actually the easiest job on the car by far, why cant it all be this simple!!
Least now when im testing things up and down my street theres less chance of someone running in the back of me!
When the clam comes back off for when we remove the roof to mould in carbon I still have quite alot of cut out of it, when its done it will look the same as this
bolted on my old diffuser tonight, would sound like a simple task but it was anything but, started on it at 7pm, didnt finish till 11pm!!
Turns out that that it looks like the diffuser on the exige has different hole locations than the elise one, ie the holes are much further in on the exige body(about 25mm) but the clam sticks out much further, must be about 50mm
Which meant I had to lie in the dark with a torch in my mouth while I trimmed a 20mm strip of bumper off all the way along on the inside so I could get the panel fixings on, the battery dremel made things interesting!!
At least now I have everything all lined up and bolted on, I wont be running this diffuser for long, just need to keep it to use as a template for where the holes are, ill be making one in a few months that extends another 200mm in length and another 100mm wider each side, that way when I seal in the area around the wishbones I will be able to make use of all the air travelling under the car, same as the gogreen car in the previous post.
Olly from phoenix was kind enough to lend me a roof clamp for a while as I dont have one, but being big and heavy and I would have to give it back to him anyway I decided to make one in carbon fibre, which since they dont seem to be that common or easy to buy in carbon or GRP ive decided to offer them to members looking to either save weight or if they have just bought a hardtop.
So start off with waxing the part with mould release wax then glueing on some edges
Nice layer of gelcoat
to make it stiffer we used some offcuts of carbon fibre as the first layer
We then added a layer of fibreglass and a foam core
another layer of fibreglass and start the last layer of carbon fibre
All done, just got to wait till thursday night to take the clamp out of the mould
Well released the clamp from the mould, strangley very easily, but then I did put alot of wax on it first
Cleaned it up and got my mate to put it in his work oven today, it needs to stay in there for a couple of days to make sure its cured all the way through.
We can then get the carbon and kevlar and make our first clamp
Also I ordered my lightweight engine mount and adjustable lower mount so that will save a bit of weight, another thing that cant rust and stop my engine moving around so much, the aerocatches are on the way also
Just need to check the bank account to see if ive got enough for my wing now
Manage to finish work a bit earlier today so started on making a splitter.
This is basically a template as my mate has decided we have to make one out of carbon fibre due to the weight so if I mess anything up it wont matter to much.
So its bolted with the 9 standard M5/M6 bolts onto the crash structure to start us off, then I added 2 tie bars at the sides as they seemed to be the most flexable part(i would have liked to have run longer tie bars but didnt have any)
need to buy some longer bolts for the ones that go into the splitter as theres not enough thread left to fully screw into the tiebar while having washers both sides so ill be off to b&q tomorrow to get some longer ones
I had to trim the chin to allow for the tiebars and also the edge of the chin would hit the poitn where the crash structure touches the splitter
Put 2 more tiebars into the crash structure to stiffen the leading edge up, though on the carbon version ill angle them out a little further rather than straight down as they are now
So the plan tomorrow if I get time is take the car up the 70mph dual carriage way, friend in another car filming just to see if we are getting any bending anywhere, to be fair if it does bend at least ill ive made it for free and its only bolted on short term.
Its slowly starting to look like a real racer!!
Got back in after and opened my boxes from Eliseparts to find my lightweight engine mount, adjustable mount and new headlight covers.
I also ordered a lightweight crank pulley but then later questioned is it like the stock one with 7 grooves, turns out it only has 5 grooves and since i run a 6 groove belt because of my supercharger it turned out I cant use it, luckily I called back before they had shipped it out.
I might do the engine mounts this weekend if I have time and motivation.
My carbon clamp mould has also now fully cured from the oven so ill be trimming that ready to lay the carbon in
Also fitted my engine mount today, thank god I have long fingers as its not easy to get your hands in the right position, so hopefully worth it, its always nice to get rid of something rusty!
We also weighed all the parts that came off and the new parts that went back on and there was a 1.737kg weight saving so not quite 2kg I hoped for but not far off, just have to see how rough it is to live with day to day.
will fit the lower mount tomorrow if I have the time, then it should be nice and solid
Also fitted my rear top brake light, that was a real pain getting it out of the 111s clam as you couldnt get your hands at anything, much easier on an exige
Then marked up my carbon sheet ready to be cut out to replace my rear window, once cut out all bond it in so hopefully it wont sound as noisy in the cabin as before.
finally been working on a design for the rear wing and confirming all the measurements on the car and the wing itself, im following the same lines as others have done only my connections to the longerons will be made of carbon rather than normal ali
So when done will effectively look like this
Bit of an update, fitted my rear numberplate which only took a moment, the biggest thing I had to do today was fit the adjustable engine mount.
The only way it would ever take 30mins would be if you were on a ramp with the undertray and diffuser already off!!
Trying to unbolt them with a spanner and socket set was getting me nowhere.
After 20mins of pulling as hard as I can I eventually got the bolt to turn that is closest to the rear then had to put a 19mm spanner onto the nut on the otherside while a socket on the other, not sure how people do it when they dont have arms as long as mine!
Next came the bolt closer to the sump…dont know what idiot put that on there but they never had intention of anyone ever being able to take it off!! it took a blow torch and a impact gun to get it to come off, which again is not easy to do lieing on your back looking up.
so the reason for the post is in regards again to weight saving, I weighed both the EP mount kit which came out at 495grams and the original which came to 850grams so 355g saving
So overall as well as stiffening my engine up I saved a total of 2092g which is never a bad thing.
Took it for a drive up and down the road and you can feel that stiffer engine mount, the cover that sits on top of my stack dash now vibrates!
Do I feel that it makes a difference, when the engine doesnt move as much under throttle compared to before but I dont feel it has made the throttle responce to anything any sharper.
Have people felt a difference from it?
Took it for a little spin up the road today, just to check everything works, all seemed ok until my indicator lense flew off then got run over by the car behind which was a nice feeling so looks like im spending £50 on a new one
While I was out I put some fuel in to get it off refill so I could get it weighed, so with 15ltrs(12.75kg) of fuel on board it weighs 710kg, now i need to add the headlights and engine cover which is 5kg combined, so this puts me at 703kg without fuel onboard which is pretty decent since ive got that super heavy ply splitter on the front and about 22kg of supercharger kit, since i know already of 36kg that can come out it looks like im on target!
Made a little progress tonight as I would like to take it up the cat and fiddle on sunday for the meet
Fitted the carbon panel to replace my rear screen, only thing I need to get hold off is either some foam or a door rubber to go on the top edge of the carbon where it meets the roof to give me a good seal.
Also my aero style catches arrived, came quicker than I expected.
Never done anything like this before so first thing I did was make some brackets out of 1mm ali, I will replace them with carbon, but I can use these as templates while I learn what to do.
Scared myself silly making the first hole into the engine cover thinking ill be calling equinox for another one as ill mess it up, good thing about making the brackets in ali was that when my bits didnt line up i just bent the bracket so that it fitted, once we got the first side fitted and checked I measured from each edge on the cover and duplicated it on the drivers side.
I then attached it with both and success, seems to work well!!
Tomorrow ill put the final one at the bottom which will finish it all off
