Mine (S1) had that where the water actually leaked down the windscreen pillar and appeared in the footwell. You haven’t been removing your roof have you?
Hi IDG - No I haven’t (yet) but the dealer did to sort out a very annoying squeek, but we had the leak (sorry ingress) before they did this.
The dealers been talking to the factory who came up with a few ideas and at a Lotus trackday @ Knockhill (brilliant as it was their cars) I spoke to a Lotus Technician, says sometimes the cars not sealed properly at the back of the chassis rails and this doesn’t show up during leak testing at the factory as the water only becomes visible once the car is parked on a downward slope, however, they’ve tried this I think.
Dealer says they will have a Lotus Technician at the dealership at the end of the month, it’s not exactly rocket science is it?
My engine is being “blueprinted” or rebuilt taking the opportunity after a bad HGF repair (leaks everywhere and head rattling)
Gearbox off as well for some preventive maintenance (and the small matter of fitting a Quaife LSD), rear clam off (because I needed to), front clam off to be resprayed, wheels powder-coated.
I am at the point of assembling the front.
Somehow, putting the things back together is much slower than taking them off.
But that’s the attention to quality you need.
I doubt very much any mechanic or Lotus dealer would take off any rust found on a bracket and repaint it, or clean the insides of the clam, or the insides of the front end to bring it to an as-new condition, or change (or clean) any rusty bolt, or substituting bolts that rust by alloy ones, or closing the holes (found on front clam removal, in the fiberglass part of the front cabin, where the oil pipes come out from) with proper-sized rubber plugs and fitting some thick insulating material to the oil pipes, etc.
They think they’ve found the water ingress problem - wait for it - wait, ok: some Muppet at the factory didn’t fit the seal between the roof and the rear clam (the one you can see from outside, if you knew it was supposed to be there in the first place), dealers demo is also the same so they didn’t realise either.
Now we just have to wait for the part to arrive!!
Good news though is we get the car back until then presumably with a bucket and squagee (not sure about that spelling!)
Anyway looks like it will be usable before yours Uldis (sounds like your doing it the right way after all that work you’d want to know it was spot on).
One more question - anyone know how to change their user name (the one that’s shown above, I feel a bit of a p**k as the only one using his normal name), failing that how can I contact Exiges.com as the ‘contact us’ link seems to be blank?
or Mean Like
or Main Keel
or Kean Mile
or … Mike (no thats rude!)
And I go by my real name - loads of people call me Tone
Some call me Tony and some call me… (no thats rude!)
Tony
(But his grandson calls him Grumps! Sometimes we wake up grumpy sometimes we let him sleep!!! …Nickie)
Anyway - I’ve now seen what the missing seal looks like, one of the guys at the showroom (Chrysler guys) said “see that’s what happens with hand built cars”.
