Snapper
A BIG THANKS to Mr Demon/David for taking the time off today to take me for a ride in his Exige with the ECU Upgrade mixed with an ITG and a Sports Exhaust. Yes I did look under the boot cover to make sure that and ITG was fitted.
The good news is that as suspected the characteristics of the ECU Upgrade is the same on an Exige with ITG and a Sports Exhaust as it is on a Standard Setup Exige.
My findings are as follows:
There is a definite change in performance and sound at 5700-5800rpm on both cars. Maybe not as much as when it was at 6200rpm on a standard ECU, but not that far off. I would also say that the cars with the ECU upgrade seems to have a fraction more torque from 5600rpm which makes a very big difference when trying to keep the car on cam.
My view is that this ECU upgrade is worth the money and is a big improvement to the N/A Exige S2. But I am not convinced that the ECU that I have been sent is working correctly.
All this driving around the Midlands to look at different peoples cars ridicules the comments by Russell at Lotus Motor Sport, that the problem is the ITG. I have also had messages sent from others with the ECU upgrade and have ITG’s fitted as well. They don’t have problems ether.
If Russell�s comments are correct, which I suspect there are not.
It does beg the questions of if this is a true Lotus Motor Sport Upgrade and they know that induction kits are standard upgrades why is there no leeway for induction kits in the mapping if that is truly the issue, which I suspect it isn’t. Or, Why they don’t have a map for them if Lotus did the mapping.
I suspect that Lotus did not do the mapping and that is why Russell is just blaming the ITG because they don’t sell it and they don’t have any control over the mapping themselves. It is easy to just blame the induction kit than deal with the problems of an ECU that is not working correctly.
It may also explain why they don�t send out another ECU to test on the car seeing that I don�t get any real sensation or sound of second cam.
Now both cars, Alun�s & Dave�s are Black Exiges and mine is Magnetic Blues.
So when I go back to Russell (Or get my dealers to contact him) I will be waiting for the comment, �I would like you to try one more thing, can you just respray your car black and you should find that everything will be alright�, �If it isn�t we might deal with the issue�.
Thanks to everyone who has been so helpful in helping me get to the bottom of this problem. If only Lotus Motor Sport was as helpful and didn�t expect me to pay a dealership to do their leg work to try different options that should not and have been proved not to make any difference.
