First post for me on this forum and straight away a thank you to those who unwittingly helped me solve my 5500rpm misfire problem. As many of you suggested checking the wheel speed sensor connector fixed the issue straight away. All before I even joined…Cheers Folks.
Now to more serious issues…I have been living with my S1’s top end rattle/knock for a while and beginning to worry it may not be normal. It taps under load, more so when cold but is quiet when the engine is not under accel load or on the overrun. Can anyone confirm if this is common with VHPD K-series (my friends VVC unit sounds sweet as under the same conditions).
I’ve read that some of you have had top end re-builds done at reasonable rates, can anyone recommend anywhere in the Midlands?
I’m starting to go knocking crazy.
PS engine has done 45000 but was rebuilt at 20000 by Lakeside.
Well then my friend get yourself “into” leamington spa and drop round and I’ll take you out in mine and you can compare.
drop me a pm as I’m about 2 mins outside the centre of Leamington.
I have some time off next week and we are house-sitting for the in-laws in Warwick. I’ll also have my SC Honda beastie with me if you want to compare yours to a proper engine Let me know if you fancy meeting up for a drive.
And mine in Coventry. Loads of proper Exiges closeby.
As for the original question, sound like it may need a top end rebuild, mine did at 28k miles, cost about �800 but that included the ITG filter and a new set of exhaust valves
Ben - be interested in a px ride in your car now the sc is fitted - I will send you a pm later
Looks like my little old Black K series will be properly outgunned by the Local screaming Honda hybrids but I’ll see you there to, rattle and all…
Cheers chaps for a very pleasant evening standing in a pub carpark
I am not certain but I think Con liked the SC Honda
Con also reminded me that a standard Exige S1 is plenty quick enough down Warwickshire country lanes,…You had quite a lick o’ speed going there matey,…I had to use full throttle sometimes to keep up
