Two companies that are good for gas struts: RS components, have a range of sizes and types, one of which you can blead the gas out to your desired setting, also do various brackets etc. On the web, www.rs.com. Also a company called Eckold make many types, also on the web. Hope this helps. SIMON.
This site is dedicated to the preservation of the African Rhinoceros. Poaching has been the main cause for the decrease in numbers of rhinos. Due to the poor economic conditions in many African countries, poaching has provided locals with a means of generating income. Another reason for the decrease in the rhino population was because they had often been considered vermin by game control officers. Herds of rhinos often trampled crops, which was damaging for an agricultural driven economy.
At Rocket, we believe the major OEM players have huge advantages over the smaller ISV’s to dominate and defend major market segments. The dominant players can be challenged by their own size and inertia. Rocket’s product development services are an effective tool to combat the paradox of size. Rocket provides major OEM players on-demand product design and development resources to bring comprehensive software product portfolios to market quickly, while dramatically reducing the up-front R&D costs.
These are slightly more expensive than the ones you mention but they are 490mm from ball end to ball end. They are also 50-400N load, the next size up I think will be slightly too strong even at it’s lowest setting from some quick calcs.
They are also multi position holding which is useful for me as I don’t always want the cover fully open.
They should arrive on Tuesday so I’ll post some details up on Tuesday night as I’m bound to have had a go at fitting them by then.
The parts arrived today and after a couple of false starts it’s done.
1st up the gas struts arrived without any nuts for the ball pins, luckily I had some 5mm ones in the garage so problem 1 solved.
2nd, I messed up the connection points and when compressed completly the cover wasn’t colsed so had to resite them.
I couldn’t physically move them initially. I got them to the point where I could compress them with force bfore fitting to the car and tweeking them then, (you should have seen how fast it opened before I let a load more gas out )
where was the problem with the original fixing you mentioned and do you think there is any reinforcing of the holes you made at each end of the fitted strut needed? also do these struts also allow you to partially open the hatch ?
If you look at the 3rd pic there is a white dot above the lower fixing point, this was the original hole, it meant the cover got to withing an inch of closing when the strut travel run out.
As for reinforcing I’m not sure. The lower point is pretty thick & tough so should be okay, and the point on the cover is similar as I have mounted it just below the 2nd air hole where it is more solid. The ball ends are pretty loose (i.e. little friction) so should keep the stess levels down. Keeping the gas pressure low will also help, I think I still need to reduce mine further.
The struts have a small lock ring (brass ring at bottom of strut body in pic3) which allows you to lock it off at a lower height, I haven’t played around with it yet.
My original plan was to move both ends, i.e. the lower one up and the upper one a lot further along the cover but then realised I would never be able to get the nut on the cover end (it’s bad enough where it is), so took the easier option and lowered the lower one, therefore lowering the open height.
MArk, looks like a really good upgrade, any chance of posting some dimensions of where you found the mounting holes to work, plus strut details so that I could copy it.
Many thanks, SIMON.
I can imagine you gave it a lot of thought, but I’m tempted on buying the shorter ones and trying to fit them further front, so that even with a smaller stroke it opens more.
