Exige S1 Wiring Diagrams/Pinouts
Hi all,
Sorry if this has been covered before but had a look around and cant find anything! In the middle of a Honda conversion on a Exige S1 and in dire need of a pinout diagram of the cabin side of the bulkhead engine loom connector.
I am trying to connect a Maidstone Link Loom with 13 splices but don’t have a reliable diagram to know what colour goes where!
I have the Exige S1 service manual but not proving to be too helpful.
Any help would be greatly appreciated.
Cheers,
Rich
Hope this helps a bit …
Rear Bulkhead Multi pin Connector
Pin Nos Lotus Loom Operation
1 Yellow Injectors Power
2 Blue Sensor to ECU - Earth ?
3 Slate +5V from ECU for sensors ?
4 Green Power NVH/IACV
5 Black Immobiliser to coil pack
6 O2 Sensor
7 O2 Sensor
8 O2 Sensor
9 Green/Pink NVH B solenoid
10 Black Signal Ground
11 Grey Coil
12 Brown/Orange Injector 1
13 Brown/Green Injector 2
14 Brown/Pink Injector 3
15 Brown/Red Injector 4
16
17 Black Signal Ground
18 White Coil
19 Green MAP Sensor
20 Blue MAT Senor
21 Yellow ECU Water Temperature
22 LightGreen/Orange Barametric Sensor
23 LightGreen/Black Canister Purge
24 Green/Brown Reverse switch
25 NC
26 NC
27 NC
28 NC
29 NC
30 NC
31 Black Power Ground
32 Red/Black Left Hand Sidelights
33 Red/Orange Right Hand Sidelights
34 Red/Slate Alarm
35 Green/Yellow NVH A Solenoid
36 Yellow/Grey Speed Sensor
37 Purple/Yellow Speed Sensor
38 Black Power Ground
39 Green/White Right Hand Indicator
40 Green/Red Left Hand Indicator
41 Black Immobiliser Ground
42 White Throttle Position Sensor
43 Green/Blue Water Temperature
44 Green/Purple Brake Lights
45 Yellow/Purple Inertia Switch to Fuel pump relay
46 White Crank Sensor
47 Black Crank Sensor
48 Red/Yellow Fog Light
ECU Connector
Exige ECU Wire colour Connected to
1 brown / orange Injector 1 *
3 brown / pink Injector 3 *
5 brown / red Injector 4 *
7 black -Ve
8 green Ignition unfused
9 yellow Coolant temp
11 brown MAT A
15 brown / blue O2 sensor signal
21 white O2 sensor -ve
22 brown / green Injector 2 *
27 black -Ve
28 black -Ve
29 grey Coil Pack -ve
35 blue throttle/baro/map/coolant/mat/speed common -ve
36 white Throttle pot
37 green MAP sensor
39 green / orange Barometric B
45 green / orange OBD2
48 black O2 sensor heater
49 white Coil Pack
53 orange / violet fuel/injector relay (requires a switched +12V) **
55 violet +12 unswitched
57 blue / grey cooling fan relay
58 white / black Tacho
59 blue / yellow Half speed fan ***
61 violet / brown Heat Soak pump
64 black / green Air-con
65 green / brown Air-con
67 black -Ve
69 pink / blue Air-Con control
72 orange OBD2
73 white Crank Sensor A + 47KΩ series resistor
75 orange / brown ECM speed sensor
79 black Crank Sensor B
80 green / yellow nvh butterfly A
81 blue IACV
84 green / pink nvh butterfly B
85 green / black canister purge
86 grey throttle/baro/map/speed +5V
87 green / blue OBD2
88 green / red OBD2
Or are you after the Honda engine loom and ECU pinout?
Thanks for the info Andy, think that’ll help me out, much appreciated.
Muu - should be ok on the Honda side of things but ta for replying.
Just wanted to add thanks for posting this up. It was very useful recently along with another previous post on here
when I needed to get to grips with the Emerald wiring on my car.
:slight_smile:
:thumbup: Brilliant don’t be stanger…
