Exige S Gotham question
Pulled the injectors, all were fitted perfectly and can’t see anything amiss.
Map it is then :frowning:
I’ve put the OEM injectors back in and think I will be asking for Essex to put my old map back on… They are 40 mins from where I work in London so may drive up there.
Alternatively I might see if it will limp to my deaer to reflash the ECU. Might not run on OEM injectors though. If it does run, then the Gotham map wasn’t loaded up properly!
What a PITA.
Oh and I have a CEL too.
Pita indeed :frowning:
Seem to remember you were quite meticulous fitting injectors in the past ,so can’t doubt your attention to detail
Maybe get a factory 260 ecu ?
Controversial I know ,but it’s a nice product …
[quote=MarkyB]No just a fixed map for a standard Exige.
I’ve had one before which worked fine. Always better to go and have it done but they are a long way from me. [/quote]
Ah , i know what you mean , it’s over a two hour drive each way for me and last time I was sat there from 8am till 7pm then the drive home , I didn’t realise they did a plug & play .
Hope they sort it , pain in the arse when it’s nothing you have done .
JFK, yep I borrowed a borescope from work last time to ensure it had all gone in correctly :smiley:
This time was straight forward, but it’s time consuming and i’ve lost my weekend basically.
Just put the OEM injectors back in, did an ECU reset and it’s driving far better than with the bigger ones! Idles and revs perfect.
Which is interesting.
Fuck this - i’m getting dealer to reflash my ECU so i can actually enjoy the car :s
ring Wayne Monday, this all sounds very odd
Injectors back to Wayne for flow testing… And the ECU for a double check.
lets hope it is an easy fix :wink:
Sorted - wrong injectors!
Wayne has been spot on at sorting it out though, and kept me sweet :wink: mistakes are easily made, its how you fix them which counts. By all accounts an easy one to make, as there are 2 sorts of denso green injectors. One type are a lot smaller than i need though :wink:
Should have it back to fit tomorrow.
Result !
I can imagine your sigh of relief that it wasn’t your fault…
Bet you’ve gone to sleep questioning your fitting the last few nights .
Exactly!
Although i fitted and refitted it so was sure it wasnt me :smiley:
Wanted it to be something conclusive or i would have lost faith.
good news indeed :slight_smile:
Although i discovered that whilst my car has switchable TC, it doesnt have the connector under the dash to allow the varible TC knob to be added. Bugger. wayne put the map in for it bit cant use it.
For gays like Jonny anyway :smiley:
[quote=MarkyB]Although i discovered that whilst my car has switchable TC, it doesnt have the connector under the dash to allow the varible TC knob to be added. Bugger. wayne put the map in for it bit cant use it.
For gays like Jonny anyway :smiley: [/quote]
:smiley:
Amen to that.
Glad its sorted matey!!
Cool , looks like you have perfect weather today for testing :sunglasses:
