Right, so the boot was a bit of a mess - I had done an initial tidy up when I got the car, but knew I wouldn’t do it properly until the car was back from paint due to rear clam coming off and all the cabling and oil pipe having to be dragged through
As I mentioned before I found deposits of oil in the carpet, so I knew the Accusump had been a bit leaky…
After speaking with Canton they thought it would be the pressure release valve - if you keep pumping full of oil and don’t’ dump it, pressure will rise and it will mist oil. When I got my car I found the accusump wasn’t actually wired in in terms of the release valve, so this seems to have been what was happening. Oil kept being added but the valve did not allow it to release so before it blew it released pressure.
As a precaution I changed the control solenoid valve and pressure switch anyway, this is the switch and solenoid in question, well its library pic as I can’t find the pics I took of replacing it
I didn’t really know how the Accusump worked before I looked into so here (lots of people make authoritative statements without knowing its basic operation) is an explanation if you are really bored, only reason I mention it is several people have just said to rip it out - but I quite like its simplicity now I understand it. I thought it might be useful when people are trying to work out the point of them
The Accusump is just a simple syringe which fills with oil and has a spring (air in this case), oil is pushed in by the engine under normal running and the spring is compressed
When the oil is needed due to low pressure in the engine, the valve is opened and the oil is dumped back into the engine to prevent starvation
This is an augmented view of the Accusump showing the air spring against the ‘syringe’ head
When the Accusump is completely empty you need to precharge the system, effectively providing the spring to push against the oil, so the dial even when empty will show about 15PSI
Here is an actual Accusump pulled apart, its all quite smooth with flow of the syringe so the brackets are on the extreme end, putting a clamp in the middle would likely block the ability for the piston to move:
So under normal operation the oil pumps around and slowly (well within a few secs) fills the tank, so apart from needing an extra litre of oil on fillup you don’t notice it
When low oil pressure coming after the pump is detected, the signal is given to the valve to release the oil and it dumps it back into the fuel circuit, a check valve prevents it flowing back to the sump
And that’s it really, it also does this just before start up so the engine is preoiled, this is the main reason I have retained it. That and the kids still think I have a can of NOS in my boot after watching the documentary Fast and Furious
In the future I may add a T piece on the pressure guage to put in a sendor, then I can use this to run a guage on the dash so I can seen when I am empty - this is clearly in pointless nerd territory, but then so are most of the changes I made…
Heres and example of the setup I plan to copy
School lesson over, carpets and mounting brackets all stripped out and cleaning began
Looms were stripped of felt tape as some were either gummy, or had a some oil - all were stripped then retaped so it was all OEM looking again, wiring itself was all good so no issues to report
Battery mount was looking a bit tired:
So was wetsanded and polished:
Wiring like the alarm switch was tacked in properly, not used gaffa tape like Lotus thought would do
For those that want to know, here is the Accusump routing out of the boot, the mirror of the wiring harness, and you can also see the reinforcement plate for the wing that I wondered it it existed, it does
I need a new can of tyre gunk as mine is 10 years old looking at the date, so doubt I can rely on it
Carpets that are now protected, replaced, and trimmed the wheel arches as they just had primer so looked crappy rather than ‘because racecar’, power feed to cabin added - the yellow and blue cables are camera and reverse signal routed from cabin and will be wired in shortly so will also be out of sight
I will also be planning out a bus bar arrangement to mount the cables on the battery rather than direct as it was already a bit crowded with the various extra bits, and maybe a LiPo to take out a few more KG’s
