The gas struts on my car are preventing the cover from sitting properly, so I’m going to take them off.
Is there a single manually positionable strut I can buy from somewhere to hold the bonnet open, or alternatively any other solution that is able to hold the cover open?
You can make one out of ali tubing with holes in the end to latch on where the gas strut comes off (take it off, you’ll see what I mean)
I bought mine from RLS because I have more money than neurones.
Is the fixing location already on the car, that RLS stay looks like it has a dedicated fixing hole. Is there a suiable propping place on the underneath of the engine cover?
I got myself one of those RLS props earlier this year - does the job well and neat stowage with little clips.
BUT
Because my car was an early one with gas struts, there was nothing to attach it to at either end on my car. There were threaded holes in the lid and latch cover, and I discovered that you can remove the ball joints from a gas strut and these fit into the holes to create a mounting point at either end for the RLS prop. Location at the car body mount is not that convenient due to its position - think this would be rectified by fitting the upgraded latch cover as found on later cars which has the prop mounting situated higher up.
[quote=Jonson]I got myself one of those RLS props earlier this year - does the job well and neat stowage with little clips.
BUT
Because my car was an early one with gas struts, there was nothing to attach it to at either end on my car. There were threaded holes in the lid and latch cover, and I discovered that you can remove the ball joints from a gas strut and these fit into the holes to create a mounting point at either end for the RLS prop. Location at the car body mount is not that convenient due to its position - think this would be rectified by fitting the upgraded latch cover as found on later cars which has the prop mounting situated higher up. [/quote]
Not quite sure what you’ve done here. Mine is a MY09 car and you simply unclip the gas strut from the ball attachment at either end. May have misunderstood you but certainly a simple fix for later ,single strut, cars.
