Dirty MAF
Think its this one but i will check on the car.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180617572480&ssPageName=STRK:MEWAX:IT#ht_2536wt_907
No. 13 is ya MAF
http://www.deroure.com/diagrams.asp?TBL=1124&MAK=1&MDL=12&SMA=1&SMO=0&ST=&SC=0
as said earlier, use scroll bar to find no. 13
Ok I was in my garage at 8am armed with a spanker MAF and pre cat Lamda sensor to sort the motha trucking stalling .
Lost some more skin and played bang the exhaust and garage floor with my head for a bit and got them in .
Started the car and left it to run for a bit and then went for a drive , everything seems cool .
I data logged some MAF readings on the kiwi , anyone know what sort of numbers I should be getting ?
Moomin ur a star !
What’s up wi yer car?
Don’t you read that the MAF does nowt?
Closed loop / open loop the fueling dont change…
Just fit a bird catch can and all will be good !
[quote=jfk]
!@@! [/quote]
LOL!!!
Yeah I have seen your bird :slight_smile:
Bugger , thought I was doing well , it says MAF rate and the numbers go up n down , there not real MAF readings then ?
[quote=jfk]Moomin ur a star !
What’s up wi yer car? [/quote]
When the car was hot it would stall when slowing down .
A known fault with the Exige S tune, have Lotus reflash it with their latest…
I have the Gotham tune !?
[quote=moomin]
When the car was hot it would stall when slowing down . [/quote]
You could check the wheel speed sensors …poor connections sometimes manifest in stalling when slowing for lights etc… happens to mine if I disable the ABS
Great another sensor ! It seems ok at the mo but I’m going to Notts later so we will see .
I have a Pipercross VIS coming monday to get rid of the nasty TRD box , it could be that .
Frank , if I can’t sort it would Essex autosport be able to find it on there laptop ? I have tried calling Wayne a few times but he’s a bugger to get hold of .
They all stall sometimes, the later core ECU software from Lotus does help but mine has the latest on he 06 ECU and still does it sometimes. I have looked for fixes and never succeded sadly
It never stalled before , I have had an 04 NA and a 06 S also with no stalling , i have had this 08 S240 longer and more miles though.
Was it you ?
I think part of it maybe driving style as well, I tend to dip the clutch almost as I stop while pulling up to lights rather than coasting, maybe that is a difference?
Essex should be able to tweak things if they do a road tune after their dyno tune…
There is a small brass orifice in the supercharger bypass actuator in the hose barb that can get dirty over time causing A/F fluctuations on coast down and poor responce time with the supercharger…
I removed mine on day one…I like things snappy
Plan C , I’m going to take the TRD airbox off and fit this today, the carbon is a real bonus :slight_smile:
Nice worktop!
i thought TRD was the way to go…i’m about to fit one, am i making mistake? The carbon king would approve I’m sure.
The fit on my TRD was pants , You can have this TRD if you want it .
