If you want a wiper blade than is way better than the standard S1 blade and arm - order an S2 arm and blade from eliseparts.com — they work much better than the standard S1 blade. Or am I just a slow learner?
they easy to fit?
they easy to fit?
Careful Nath…think of originality!
they easy to fit?
ha ha
Exactly the same size as S1 arm and blade
Undo one bolt that goes through base of arm (under cover), take old arm off, fit new blade to new arm, put in same position that old blade was in on windscreen and put bolt back in. Takes 30 seconds and means you have a wiper blade that does what it’s supposed to do.
If you want super accuracy mark the position of the old blade with a strip of masking tape before taking off the arm.
