Window winder removal
Apologies for the stupid question but how do the wind winders come off? The four allen bolts appear to be extremely tight. Is there a securing bolt under the Lotus badge in the center?
In a word, yes.
Take care not to strip the heads on the four bolts.
Thanks Winthattt, do you mean i need to undo the four allen bolts plus remove the Lotus badge to get to an additional center fixing?
Exactly. I think I had to drill one or two out. They are steel bolts in an alloy winder so get stuck.
Make sure your hex key is pushed right in before you turn it.
Keith
Cheers Keith, I will give it a go…
