Wider front tyres 205/45/16
Anyone running 205’s on the front? Do they rub on the arches on track (OEM suspension)?
Can only get Toyo R1Rs in this size and fancy trying a set.
Depends on how low your car is, my standard tyres rub, but I am running at 105\115
[quote=21TonyK]Anyone running 205’s on the front? Do they rub on the arches on track (OEM suspension)?
Can only get Toyo R1Rs in this size and fancy trying a set. [/quote]
Dont they do a 185 or 195??? BIG market for the 185 I reckon! :blush:
Standard everything, stock heights and shocks. Have a couple of holes in arch liners already though from a Walshy day.
The standard suspension is quite soggy so it is easy to wear them away, the 205s will be worse as the are wider and taller albeit not by much.
I’ll give them a go, if they are making big holes in the arch liners then it’s a good excuse for Nitrons.
just don’t run the ride height too low :wink:
