Why don�t more people turbocharge their cars (a la VX220) ?
Now, from what I understand, although turbochargers are harder to fit as an aftermarket product, and more difficult to get spot on; they are considerably more efficient, cheaper, and the biggest plus point I see is that you don�t have to put up with that annoying whine from the supercharger.
So why don�t people fit turbos in their Elise/Exiges? (if you can do it in a VX why not in a Lotus)
(From what I�ve heard/read it�s something to do with the camshaft or bulkhead something or other. I�m sure the answer is blaringly obvious so sorry if I�m �dumming down� the site)
Easy, because most people like the power delivery of a NA engine, i.e.: no lag.
At least Supercharging maintains that power delivery as it pulls from the bottom, and some people actually like the whine a supercharger makes
Also, there are packaging problems with turbocharging due to the heat and the fact that the car is mid engined and small. Not a lot of airflow back there, things get cooked.
AND, the Toyota can be turbo’d, Forcedfed has done it with excellent results, but to turbocharge the K reliebly I feel you’d have to start with an iron block, and that’s heavy (unless somebody comes up with a proper way of strengthening the block)
There is a turbocharged version of the 1.8 litre K series, as was used in the Rover 75.
However, the problem with it is that the turbocharger is mounted just where the bulkhead is in Elises/Exiges. So it won’t fit.
I suppose you could re-engineer it, but nobody has bothered. This is mostly because if you want a turbocharged car, you go to Bernard Scouse for an Audi 1.8T conversion, which will give up to 300bhp and by all accounts is a quality product & installation.
It’s MUSIC to my ears !! And it quite literally is behind my ears.
Part of the bulkhead is cut away and replaced with a domed cut out, NOT really enough room for a Turbo…
Wasn’t Adrian Neweys 300bhp Elise a K-series turbo car (done by BBR?)
Plenty of people are turbocharging their car (again not using the K-series like the VX220 doesn’t either !) AutoTeknix has a considerable queue of people waiting to have theirs done.
Nobody who’s been out in my car has complained of lag
Are you implying that I don�t know my engines
What kind of price difference is there between Turbocharging and Supercharging? I know that Turbo Technics charge �6300 for a supercharger, what are we talking for a turbo (I had a look on the AutoTeknix�s website, but it�s somewhat devoid of info).
Prices vary depending on precisely what you want… but it’s circa �6000 for a 250bhp Audi engine fitted (less what you can get for your old K) and �9000 for a 300bhp version (less the K)
Which makes it a good �4K-5K cheaper than a S/C Honda
I’d say as well as space and heat which are both a bigger problem with turbo’s won’t there also be more work in mapping a turbo car than a supercharged car ?
