Whooshing!
I have a whoosh!
It only happens when car engine is under load and its from the front , somewhere!
It sounds like a turbo dumping when I release the throttle. Car feels fine , not down on power , and not over temp. It started this morning and all I can describe it as is a turbo dumping its boost.
Only happens at speed , with or without the aircon on.
Ideas?
Is it the SC bypass valve?
I dont know? I have never experienced it before.
It sounds like its coming from the front not the rear. Everything else appears to be fine.
Its literally started doing it this morning .
Front of the car, or front of the engine. Bypass valve is attached to the SC.
front of the car. Sounds like just in front of the window.
I did clean the dash with a cloth on Sunday thinking about it . Wonder if I have disturbed something?
Hmm. Been out in it again , its only when revs at >3k and when I keep it at 6k rpm for instance its pronounce.
Weird.
Car still feels as punchy and the fuel economy hasnt gone through the floor.
I think it might be the bloody air con again. Had my eldest start the car and I can hear the noise eminating from the radiator area. I know it’s not the rad as I haven’t lost any water, my charge cooler is working fine , working on the basis that my inlet is cold to touch and I haven’t lost any water. Also note that my blower isn’t really blowing cold air any longer, the engine Revs don’t drop when the blue light comes on.
Silly car!
