Cos I’m sending him a nice letter about my WAL and brake pipe episode !!Many thanks
The man you need to write to is Ansar Ali - AKAIK he is CEO.
PeskyCheers [image]http://www.exiges.com/ubb/NonCGI/images/icons/smile.gif[/image]
Rob, I owe you a beer !!Had a reply from Lotus, to cut a long letter short ( with a bit of interpritation !! )- We know about these problems- They occur at the extremes of use- Your a heavy guy and you should check your ride height the correct way every week- We checked the brake pipe and put grease on it so when the drive shaft hits it next time it will be lubricated- The oil pipes are fine ( oil flows well at 150 degree C ) so squashed ones are no problem- To keep you off our back we will give you a �70 credit against the wheel arch liner you purchasedI guess you could say this is a result !!
I look forward to downing a pint of Stella at your expense then [image]http://www.exiges.com/ubb/NonCGI/images/icons/grin.gif[/image]
quote:Originally posted by Pesky:The man you need to write to is Ansar Ali - AKAIK he is CEO.Really? When did he make the jump from sales?
