Which Cambelt?????
S1 K Series needs a new cambelt as its 3 years old now…
Any suggestions as to anything to go for / avoid???
Mark
Avoid a 2nd hand one, Mark :wink:
Always used Gates 5416xs or Piper TBP17wide cambelts without any issues. No experience of other brands. Make sure you get a new manual tensioner too (no cheap copies)… and best of luck with the bottom crank pulley bolt!
Hum mine is 5 years old… Any advise on durability (car hasn’t done sufficient mileage to consider a “belt servicing”) ?
I think you should change it mate asap.
It’s not only the miles, time degrades the belt too…
I recall it’s a change every 5 years, but maybe less! :slight_smile:
Thanx Pete, I have to work on the beast this winter anyway :slight_smile:
Yeah, Pete’s spot on - don’t take any chances with the cambelt. Personally, I’d change it on a VHPD every 3 years just to be on the safe side.
There’s the Gates kit - but also the Contitech one, guess both are good quality ?
Recommendation is change every 3 years. If it breaks, it’ll be very expensive. I’ve not done many miles at all but don’t want the risk!
Mark
Interesting…
… but has anyone heard of a cambelt failing on a VHPD?
[quote=MarkPH]Recommendation is change every 3 years. If it breaks, it’ll be very expensive. I’ve not done many miles at all but don’t want the risk!
Mark [/quote]
Or roughly every time HGF occurs??
:wink:
:smiley: :smiley: :smiley: Tim you naughty boy :smiley: :smiley: :smiley:
… as the S1 guys pass the broken gearbox S2’s every 2 years! :smiley:
Usually in a cloud of steam (K series) burning CV grease (Honda) going backwards due to coming on boost mid corner (Audi)
Did I manage to catch all options? :smiley:
Don’t forget the na’s passing us all … till oil starvation kicks in due to their cornering ‘G’
:wink:
Also I won’t be able to feel whats going on through my slippers on the pedals, and even if i can the view through all the pipe smoke will be hopeless.
It will however, be very comfy as i glide along serenely, listening to radio 4 :smiley:
I think I know the answer to this. Got to get a new cam belt as well, is it really worth getting verniers and the timing done? Very limited miles but all on track. The engine is stroppy at low revs and I think many of the horses have bolted, or never existed.
Try Tesco.
Sharp !
:smiley:
I hear Tesco burgers are very rich in Shergar
