I have just found out I have been missold a fuel pump and injectors! I am not happy. Does anyone know where I can buy a Exige 260 highflow fuel pump and 440 injectors cheap!?
You will also need the new pump end cap and spacer ring if you havent got them aleady.
I have a spacer ring here.
Ta
Gav
Thanks Gav. Do you want to PM me a cost for the adapter ring?
Any ideas on the pump and injectors? Seen them on Monkey Wrench.
Denso make the pump, i know that much.
Even Lotus dont have any injectors to sell at the minute as i had the local dealer phoning me to ask if i had any they could have for a conversion last week.
You can buy the injectors readily from an American website a lot cheaper than you can this side on the pond and they take about 5 days to get here. Sorry cant remember the name of the company though…
The spacer ring is £50 + vat from Lotus.
Id be happy with £50 delivered, it is brand new.
Thanks again, I have found said website and their pump come with the adapter ring and they do the injectors too.
I will keep you in mind if I still need one though.
It may come with the new pump end cap but i doubt it will have the spacer ring as that is a specific part made for
Lotus.
Ill post a pic up later.
“This fuel pump is specially modified to fit your car and includes the required connector and retainer ring.”
Its not a retaining ring, its a spacer to sit the whole pump assembly higher in the tank.
The new uprated fuel pump is approx. 5mm longer than the standard one and requires a spacer to lift it clear of the bottom of the tank. It also needs a new aluminium end cap in replacement for the std plastic one to retain said longer pump in its housing…
This is the spacer ring with rubber O ring you need to lift the fuel pump assembly and housing it sits in -
Ah ok, I was going buy the contents of the upgrade kit from Dave: http://www.seriouslylotus.com/fuel-pump-upgrade-kit-toyota-cars
Did not know I needed a spacer too!
I wouldn’t buy a thing from MWR especially importing from the UK. In my opinion and few others they are not to be trusted.
http://www.lotussport.org/viewtopic.php?f=13&t=5171
Edit… very sure save importing anyways Track Group would be able to help.
Thanks for the heads up Jonny!
Hangar111 have a good price on the pump so I am likely to use them
Excellent glad its sorted
I stock the correct Denso pump and retaining caps
How about plastic washers lol!
I purchased injectors/fuel pump and pulley via seloc over a year ago but have not fitted yet. Is there any easy way to tell if they are the Uprated parts?
The injectors are green denso.
The fuel pump has 018L4A stamped onto it?
A standard pulley is fine for 260 bhp.
