Wheel Nut Tourque Settings
Probabaly one for IDG.
What is the torque setting for the wheel nuts on an S1 Exige?
Is it any different for the magnesium wheels using the Elise wheel nuts?
Thanks
Bryan
59-63 ft lbs (80-85 nm) for the standard wheels…
I would use the same for speedlines…
The manual say’s 80-85nm. wouldn’t worry to much about getting it just right, biggest problem we have had is when they are tooo tight and the car is warm after a race you really battle to get the bolts loose.
Darn, mike beat me to it!
Let your fingers do the talkin’‘’‘’
Thanks guys, appreciated
BTW I see references to ‘the manual’ presumably the workshop manual ?
If so where can I get one?
Thanks
http://www.myexige.co.uk/home.html
Then go to the links section
Thanks guys - appreciated.
BTW is ‘The Manual’ You refer to the Workshop Manual ?
Thanks
Bryan
The link is to a scan of the paper workshop manual.
Print it and save a load of dosh - then if you get oil on a page, you can print it again!!
Many thanks People
That’s print it from work as it’s pretty big
And then laminate it
Jason
obertightneing them can lead to shearing the studs off
