Anybody Know what the Usal operating water tem should be showing on an exige s ?
Was in trafic the otherday and got up to 95 and still no fans came in
Sounds fine to me. I’d expect the normal running temp to be mid 80s. It’ll rise in traffic, but I wouldn’t expect the fan to cut in until somewhere around 100.
Thanks
It usaly rns between 82 and 86 its just i suppose i expected the fans to come in about 90 i suppose
Even on track it never whent abouve 92
Mine runs 88 all the time.
I have seen 92 a couple of times in traffic jams when it was really hot, i did hear a fan but i guess it was the ac fan.
Ive seen over 100! but that was going up Italian mountains and mine is one without oil coolers.
Gav
Mine normally runs at 86 degrees C, but went up to 98 C on one of the recent very hot days when stuck in a traffic jam. My dealer says that as it is a pressurised system, it should be OK up to 120 C. I have never heard an electric fan cut in on mine - has it got one?
highest ive had was 105, scorching hot day south of france. was slightly concerned, glad to hear the can go safely up to 120
Think I worry to Much
make sure your fan is working… let it idle a whileafter a spirited run (keep an eye on temp guage) the fan should kick in before 100C if it doesn’t go a drive to cool it all down and then check the fan again by putting 12 volts directly onto it… might be goosed.
Mine ran to a flashing 111 deg at the recent Le Mans trackday!
She’s presently with Plans having oil coolers fitted!
