Hi all!
I have a set of new Late (Titan) VHPD Quad Throttles, but I need a set of the trumpets for it.
The factory ones are fine, or if you have some aftermarket ones I could be keen on those.
I’m in New Zealand, but can have them sent to a UK address if you would prefer.
Cheers,
Chris.
Hi Chris,
I tried to send you this info before on seloc but maybe never went through.
I got mine made by Akil at Myriad Automotive, two 90mm and two 150mm.
He made them quickly and with delivery cost £82 or something similar. Only thing I wish he had done (and that I told him multiple times) was just to spot weld the bottom ring on so the fixing screws had a flat surface to screw and tighten down onto like the OEM trumpets. He unfortunately welded all the way round so I had to use a dremel to grind a flat surface into the weld. I also needed to file all around the bottom ring a little to get them to fit in the Titans but I knew I had to do this as I wanted to keep the inner pipe diameter 45mm to match the Titans and couldn’t get the correct outer pipe diameter using the two pipes. Any filing can be avoided by having them made to the correct outer diameter but he wouldn’t be able to match the inner diameter to the Titans that way.
I haven’t fit them yet as money isn’t there to sort a new Emerald etc but I think they’ll work well. I’m sure he can make them any size you want as well.
Cheers James,
If I have no joy finding any , I’ll get some made.
