Wanted: Standard Exige S airbox and diffuser
Does anyone have a standard Exige S airbox they don’t want anymore?
Also does anyone have a standard Exige S diffuser I can bowwow to copy the hole for the tail pipe.
I’ve decided, mine is too loud and I can’t here my new wireless properly. lol.
Ta.
Oh and before anyone asks, no i’m not gay, i’m just old!!!. Might have to upgrade the speakers as the Carpenters are a bit crackly at full volume!!
Hi Sean,
I’ve got a spare airbox off an N/A S2 Exige if they are the same?
Will
Cheers Will, does anybody know if they are the same??
Yes, they are the same. Theexhaust cut out can be different depending on what you put back on, single or twin outlet? But mostly it is just a big hole
Cheers Ade.
I managed to get hold of a brand new single exit standard exhaust off an ‘S’ so may try that.
Will, it looks like your airbox will do the job so how much do you want for it and all the fixings etc?
i’m sure I have a picture from underneath the car, it might be enough to see where to cut the hole.
Ta!
Here you go
[image]http://i141.photobucket.com/albums/r53/pureitc/Diffuser.jpg[/image]
you only need the hole the size of the ally blanking plate, the other piece was removed to fit in a twin exit pipe.
Cheers Ade!
You have PM
I am still after a silver maddog diffuser if anyone has one spare? Either that or a slightly squashed std one I can pull to bits to get a patern made for an extended one like the maddog diffuser
On the subject of air boxes does anyone know the internal diameter of the pipe that connects from the box to the inlet manifold ??? At both ends (if it varies)
