Wanted: Original S1 ECU harness plug
But of a strange one but I’m looking for the original S1 ecu loom connector that’s normally cut off when you install an emerald etc…
Am sure someone must have one kicking about in the garage or in a box of bits they want to sell ?
i can probably get you a new one if that helps?
or you can just buy a new one from here…https://www.radiumauto.com/T4e-ECU-Connectors-Pins-for-2006-Lotus-P253.aspx
Have just amended the ad as its for an S1 that I’m after :laughing:
but thanks for the replies :smiley:
Pretty sure its from a BMW/Vauxhall with a Bosch ECU of that era. If you count the pins and rows, I can probably find what you are after new.
It is the same as the Bmw connector. I have a scrap BMW ecu as I was going to make an adaptor loom for my Exige when I converted it to an Emerald ECU. I did not make it as I got one already made from… You pmyhill I think!
Let me know if you want it and we can sort something out.
Update:
Connector has now gone to a good home. Jonny F.
thanks for the replies so far, the connector isn’t for me its for a mate that isn’t a member on here - but we’re looking for the plug that is on the original harness not the ecu connector
Scrap yard with some old BMWs should get you one.
I know it was a while ago, but did you find one? Only I’m having a bit of a clear out and I found my old one if you want it?
