Bit of a long shot but does anyone have an OEM oil catch can for the S1 Exige they’d be willing to part with? I believe this was part of the 190 upgrade for some Exiges and the 340R. Naturally it’s now obsolete from the factory… hoping to source an original one rather than go with a generic eBay jobbie.
Many thanks,
Dan
Geary at Elise Parts has a nice one that works on the S1. You cannot install it on the head as the coil pack is in the way on the s1, I bolted mine to the divider panel in the boot. Collects very little oil in mine but quite a lot of water.
I can only see the full ‘K Series Oil Breather System’ on EP which looks expensive at £240, and I already have the OEM breather hose
I was planning to mount the catch tank on the bulkhead but that might be a better option if it needs emptying regularly, cheers
That’s the one, it’s not cheap compared with an eBay catch can. Scratches quite easily when you pull it in and out of the holder but it is quite neat and a 30min installation task. I am surprised at how little oil blow by I get, considering it’s a dreaded VHPD.
