Wanted n/s, late s1 hub assembly with the single drilled holes for two pot calipers
I think John has a brand new one on the shelf Marc. Last one out of Lotus, so will probably be about a Squillion english pounds to you!
Two of those special squillion pound notes that you have would cover it!
Its a right hand one if that helps. But does have the second set of holes for the 4 pot calipers if that doesn’t.
sorry john it’s a left hand one I need I already have three right hand ones
I gave the last one I had away last week to inch, at the time I remember thinking i’ll not be needing that.
I need a standard single drilled one so that I can drill it for the lotus s2 four pot caliper kit i’ve taken off the project.
