WANTED: IACV, BAR SENSOR, MAP SENSOR, VACUUM HOSES (VHPD)
Hi Guys, as my car with the above parts all removed by running the injected based on TPS. I am planning to return to original spec for emission tuning. Can you please let me know if you guys have all these spare parts with the vacuum hoses the better. Please let me know what you guys have, thanks.
Sam
I have all the hoses (blue silicon) for the Iacv and a non functioning valve. Good news is the valves (bosch) are available new on ebay for about £40. They are the same as a SAAB valve.
I purchased them when my iacv got toasted in my track day cv joint fire, however, the toasted valve still works and the “new” one was dead.
IACV is essential for a sensible idle on a Vhpd.
Thanks are there a SAAB parts number i can relate to as i can see there are few different one from SAAB looking on ebay, cheers.
P.S. is the SAAB exactly the same even down to the plug so i can plug my original switch to the IACV? Cheers
Sam
The part number is
0 280 140 516
There a Bosch parts and copy parts available both new and second hand. I would go for Bosch, new or used.
Should plug straight on.
Let me know if you need the hoses.
