Off an S1 Exige please.
For the mechanically pea brained amongst us (including me) I mean the radiator that runs the air con, not the engine cooling radiator of an air-conned car.
You mean the condenser Part number A111P6035F costs about �200 new as I’ve recently bought one as my old one was mostly aluminium dust. Also if you want to hold the fans on without screwing through the condenser Lotus do actaully do a couple of brackets, but for some strange reason they only list them on the Elise with Air con not the Exige I can find the part numbers if you want.
Give Wayne and Alex a call at Pro Alloy Russ, I’m sure they could knock you one up.
It is not for me guys - I have a feeling this is a low-cost purchasing opportunity with no need for the rad to actually work - I think it is for test fitting/dimensions only.
Russ
Sean, I asked Wayne to make me one before I bought the Lotus one, but he said they couldn’t do them as they required a higher pressure test or something like that. He did try and find me a univeral one, but it cost more than the one from Lotus!
Russ T, if you just want it for dimensions you can have my old knackered one, it’s still in the garage as I haven’t got around to chucking it yet
Yes please!
OK. I’ll try and dig it out sometime this week and let you know how much it’ll cost to post etc.
Okey Dokey, ta Mate.
You setting up some kind of system to blow cold air onto your CV joints mate?!?!
No it is for my underpants Nuts Sir??
I did think it may be for the cabin, to combat the hot air that comes out of ya mush!!!
