VI thingy mi bob
http://www.vi-performance.com/homepage.aspx
Have people seen these? are they any good? What do people think? I am not interested in 0-60’s more AIT’s and AFR’s and temps etc
Looks good that one but would you be better off with a GPS type like a Vbox ?
I’ve got one…Have it sitting in a box…its a xmas prezzie off the mrs. I’ve played with it and tbh…id say it was excellent. Links via OBD port to give real sensor info. I had it for a different reason which i cant post here. But it seems epic. You can also use it to view and clear error codes stored on the ecu. Always handy.
[quote=ExigeS]I’ve got one… I had it for a different reason which i cant post here. [ /quote]
come on tell…post it post it :smiley:
I have been looking at these as a garage around the corner is selling em, but where do you plug them on an s2 exige?
ignore my post its under the dash in the middle very easy to see :slight_smile:
Would this take the place of a "typical obd2 reader " ?
So so…You can read the codes and delete them. But doesnt have the more extensive options to alter things on the ecu. Door locking speeds etc that some have. But i see no reason why it couldnt come in a future update.
If you need something to read codes and clear them…perfect with a host of whole other tricks.
Not sure how good it will be to use while driving, my OBD reader gives live data, but also interferes with the dash quite badly with losses of signal to temp revs and speed on a regular basis, this can be quite annoying :frowning:
