vauxhall XE 16v question
Ok, so it’s not Exige engine, or even Lotus… but I suspect that there are a lot of petrol heads on here who have owned or own one… !
There is a big breather elbow that comes off the rear left corner of the cam cover… I have a blanking plate for it (from QED) but I’m not sure how the elbow is held in… there is a steel baffle on the inside which I’ve not removed… is it hiding clue?
All help gratefully received!
Chris
Could have sworn I replied to this yesterday!!
From memory, they are an tight interference fit. A bit of gentle heat to the cam cover, something to grip the hose piece with and a little patience should see it come out.
You did! Is it Groundhog day??
Red diffuser then! :smiley:
Red diffuser then! :smiley: [/quote]
The one I have now is actually anodised green! It’s never occured to me, before now, that it might not be ‘normal’ :wink:
And while I’m at it - best way to clean out a dry sump tank…? With petrol? (carefully etc!)
[quote=chrisb]
The one I have now is actually anodised green[/quote]
… which is clearly made visible when you undertake a barrel roll :shocked:
[quote=Benja][quote=chrisb]
Just goes to show - you never know when your undies might be on show :wink:
